A55 Smoothing Plane
Color Coding Tools - how do you do it?
clem Wixted
>I have searched the archives looking for a thread that talked about color coding lathe tools. I couldn't find it. This is to help finding the right tool that is in a bunch of tools with the handle ends sticking up.
I would like to do this to my tools. I have just had a sharpening marathon and didn't realize how many tools I have. Now I want to organize them with some kind of logic and would rather not re-invent the wheel. I know I have seen some discussion on this. Can you point me to the thread or do you have some suggestions.
Thanks,
Clem
Re: Color Coding Tools - how do you do it?
Stuart Johnson
>Some things just aren't meant to be. I use a five gallon paint can with holes in the lid. The tips are all down so to try and keep track I labeled each hole. You know skew, 3/8 spindle, 5/8 bowl, scraper etc. I took about a week for the skew to be where the bowl gouge belonged the spindle in the skew hole and so forth. Now I make a guess that works part of the time.
I actually take out whatever I think I'll need and move them to the top of the table saw where they are handy. Of course this means once a week I have to move everything back to the storage bucket.
Dick Hines
Dick Hines
>I would say just pick the colors you want and use your color code. Like pink for all your scrapers and red for bowl gouges. Then you have someting else to remember which color are my bowl gouges?
Randy G
>I had an idea last week, but it's not working so well on my dark handled lathe tools. I've got a wood burner and I just burned a letter in the top of the tool. G - Gouge, S - Scraper, K - Skew, etc... It's kinda working, but might be an Idea for you
Mine are colored blood red
Jerry Hall
>I store mine cutting tip up in 2" plastic pipe on a wheeled cart so I can see what they are, and they are now all colored blood red (:
try it the other way
JohnKJordan in East TN
>>....finding the right tool that is in a bunch of
I can't help with your marking question, but my turning life is much easier and more efficient since I started storing my tools the other way, with the points towards me.
I have two small deep recesses (shelves) within reach, covered with carpet. I put the tools in the recesses handle end in first. I put all the skews somewhat together, scrapers together, etc.
I can instantly see what tool I need. I have not once stabbed myself with a sharp tool. Life is good.
Steven Antonucci
What I've done (developed over the last 5 yrs)
steve antonucci
>I have 3 racks for tools now. They are each geared towards a single set of activities. They are mounted on the wall within reach of my lathe.
Rack #1: small hollowing tools for tiny openings and generally 4" or smaller
Rack #2: The basics-gouges, skews, and scrapers.
Rack #3: big hollowing tools
I've also gotten into the habit of making handles from different kinds of woods, so that I can usually find them in a second or so. I have smaller hands, so my handles are almost all turned to fit me, which means I can customize them to be slightly different. Turn some beads in the end of one, burn some grooves in another...
So by separating them by type, shape, and wood, I've gotten pretty good at grabbing the right tool the first time. I have at least 40 tools...
Steven
Fog Tanner
>I do have some handles which are dyed with analine dyes and have liming wax on them. Over this is Varathene for the wear. But what I mainly do is use different shapes on the end of the handles. all my gouges are rounded and all the skews for slight cone shaped. Scrapers are rounded with some "V" grooves.
After a little while you get to whete you recognize the tool by the end of the handle, so each one is slightly different. The other practice that seems to help, is to put away all my bowl only tools when doing spindle work and all the box only tools when not doing boxes. Makes it quicker and easier to find a tool.
If you look in one of Raffan's books, where there is a shot of his workshop, he has a portable "table" that he sets across the bed for holding tools. This forces you to keep just those tools you need out. I do this when using one of my lathes and it works quiet well.
Fog
tm
>I found a 6 x 10, laid out a grid and used a forstner bit to drill
holes on the centers. I kept pulling the wrong tool because I couldnt
see the tips. I simply labeled each tool with an abreviation.
SK for skew
RS for roundnose scraper
TD teardrop scraper
FS flat acraper
etc...
Red or black sharpie on the metal just below the ferrule.
Seemed kinda dorky at first but it eliminated the guesswork
and it was very simple.
End of problem.
These solutions are too practical and simple.. :-)
Clem Wixted, Jonesboro, AR
>...I was thinking of perhaps a dot of one color for my HSS tools, then a dot of another color for carbon steel, a dot of color for the gouges, a dot of another color for skews and a dot of another color for the grind angle, etc. There would be three or four dots on each handle.
I think the reason for this is two fold. I have an electronics background and resistors use a four or five bands of color to give the various values of the resistor. The other reason is I picked up a big box of nail polish at a yard sale with a gillion little bottles of polish in many, many different colors. Then I could have a bunch of dots on the end of the handle and then use the large chart on the wall with the meanings and placement of the color dots to determine which tool meets my needs. This is a bit over the top.
But, wait, there's more.
While thinking of this I have come up with even grander method of tool identification.
It would probably be better if I put a UPC on each tool and use a reader connected to a large readout behind the lathe that would give the specs of the tool being read. But then I could get a little more ridiculous and fit each handle with a chip and light bulb that would respond to a computer search with the specs of the tool I wanted and when that tool was selected on the computer the bulb on the tool would blink on and off and then I would just select it easily.
I think I got too much sleep last night. KISS is better. I'll just use the nail polish to mark the #1 jaws on my chucks :-)
Thanks for your input,
Clem
