Drill jig for mini lathe
bhenr99
>Has anyone come up with a drill jig such as the Oneway drill Wizard for the 10" or 12" mini lathe? Oneway says you need at least a 14" lathe for their unit.Thanks for any help.
Bob
bhenr99
Bob
Re: Drill jig for mini lathe *LINK*
Mike Brazeau
>Here is one I made a year ago using bushings available from Lee Valley. It could be adapted easily to any sized lathe. Complete description is available at the link.
Drill Guide
>I don't even use the bushings. I just use Oak for my drill guide. I leave it a little thick, about 1" or more and that seems to handle the drills without wallowing out for quite a few uses. They are so quick to make it doesn't really matter. I use square stock for the top to make it easier to drill a straight hole. I usually drill 3 holes of different sizes. 2 holes on ones side, above and below the hole on the other side. I also turn the bottom round long enough that any of the holes can be centered on the turning.
Danny Wells
>Best Wood tools also makes one that looks similar to the one Mike made and they have several different drill sizes available. Theirs is designed to fit into their tool post that will also accept all of their tool rests.
>I couldn't find the drill guide on their site but I will be working with Vic and Sharon today so I'll ask them if they have the drill guide.
Colin Spencer
>Bob
Sorby make a very good one that fits in the tool post and they have it with many different sized tool posts.
Colin
Don Evans
>Any of you remember the old "very cheap" table top drill presses? The one's that you mount a hand held drill in. That is what I have used for last 15 years to drill on the lathe. I use the bottom stand of it to store the unit but leave the screw (in base) loose so I can just pick it up by the post and slide that into the banjo.
This allows very easy drilling and once the height is set for your lathe it doesn't have to be adjusted for future use.
To drill, just use the handle on the unit to move the drill. These allowed mounting the drill vertical or horizontal, so on the lathe you use it in the horizontal position. I was lucky enough to find one of the very old (meaning well built, study one's) of old. I also have one of these that is made for a dremel. They are about $50.00 and offer much more flexibility than any commercial unit made for this purpose that I have seen.
Don
