Partitioning the workshop
Bob Macgregor
>When my new lathe comes in, I'll be placing it in my basement shop closer to my forced-air furnace. To reduce the spread of chips and dust, I want to install some sort of partitioning system around my lathe. I don't want to make this permanent walls, so, at first I was thinking of a bunch of shower curtains. It occurs to me that, alternatively, several wide pull-down window shades might do the trick nicely.
Has anybody used this approach? How well does it work (ie, does it keep chips in and does it help with dust control)? Does dust adhere (electrostatically?) to the shades/shower curtains very much? Do the curtains get in the way when you are turning...or not (shades would retract right up to the [low] ceiling]? Any design warnings or advice will be appreciated.
Re: Partitioning the workshop
Brian Hahn in SW Wisconsin
>In my old basement workshop, I first used old shower curtains hung from nails in the joists overhead. I soon changed to clear heavy polyethylene sheeting (5-mil vapor barrier) with loops taped on. The clear polyethylene improved the ambient lighting around the lathe and I could see when someone was approaching. I made them long enough to reach from ceiling to floor, which made the lathe area pretty humid when turning green wood. On the other hand, making them floor-touching length did a better job of containing the debris, plus it helped stop the "rollers" that were headed for the sliding glass doors.
Mike Brazeau
>Hi Bob. I can sense the desire for your lathe to arrive soon! I am in one bay of our three car garage. I used vinyl coated clothesline wire strung from various points with turnbuckles to tighten. I have shower curtains from the dollar store strung on them. It is working out very well. In one case I just flop the curtain up on the wire to get it out of the way when not turning. In a basement old drapery track will work well also.
Bill Hale / The Wood Spinner
>Bob I also use the shower curtains from the dollar store. I hung some old pipe from the ceiling and put the curtains on that. I do have to modify this as I have 10 ft ceilings. At this time chips go over and under so I need to lower what I have to the floor and add another to go ceiling high. Cheap and easy ! Get clear if you can.
Good turning and be safe
Bill in CG, AZ
Pete in Holland, MI
>Bungi cords and blue tarps do the trick for me.
Be cautious around your furnace and a wood working machine. They have open flames. You make dust. Need I say more?
Also, having your furnace close to a wood working machine will make it easier to suck any dust from the air and deposit it on your wife's side of the house. I'd consider walling off the furnace from the work shop with a real wall.
Bob Macgregor
>I've noticed the curtains in a few past shop shot postings, which gave me the idea. The reason I thought of using old-fashioned pull-down windowshades is that I envisioned myself catching the shower curtain with my shop vac and sucking the whole setup into the bin! Maybe I just have too vivid an imagination?
Thanks for the suggestions/voice of experience.
BOB
go for the gold *LINK*
JohnKJordan in East TN
>You may want to look into commercial curtain partitions. When I worked they were used in laser labs and weld shops to protect the eye, in an extreme machining operations to minimize temperature fluctuations, and as room dividers in other labs. These are made from a variety of materials - it would take a monster shop vac to significantly disturb those I've seen in use. I plan on using curtains like this in my shop to let me keep my lathe area warmer than the rest of the building.
You can get track mounted curtains that slide or roll up curtains, kind of like the window blinds you mentioned except on steroids.
Try asking Mr Google for "curtain partitions". One such link he gave me is below.
curtain walls
I never had a problem with the vac.
>Used shower curtains, as opposed to cheap-o curtains, are a fairly heavy vinyl, as is the 5 mil polyethylene sheeting that I used. The shop vac did grab them on occasion, but never managed to inhale more than an inch or two of a corner. The cheap plastic painting drop clothes are a different matter entirely!!!
