Advice on Grinder
Advice on Grinder
Advice on Grinder
David - Indianapolis
>Looking to pick up a grinder for sharpening lathe tools. Woodcraft has one on sale, says slow speed, equipped with two 8" wheels, 120 and 60 grit aluminum oxide. $80. Does anyone have this grinder? Does it do the job? Any recommendations one that a number of users are pleased with?
Thanks,
David
Re: Advice on Grinder
Allen Neighbors
>I have the two speed Delta grinder, and never use the higher speed. I'd say this one is a good deal.
Stuart Johnson
>This is the grinder I have and I've not had any problems. Some have reported excessive vibration and have returned them for replacements under the warranty.
Re: David- that is the best buy you will find.
Jamie Donaldson
Lan Brady
>David,
I bought the same grinder 3 years ago. Still on the original wheels. No problems yet.
Lan
JohnKJordan in East TN
>I bought that one about six years ago on sale and I think it is worth the cost.
Best one out there for the price...
Peter Teubel
>I used mine for 3 years in a production environment and it's still working fine. Can't beat it for the price.
and most people own this grinder..
Doug Thompson near Cleveland
Re: Best one out there for the price...
don in central illinis
>I bought the same one, before it was on sale, because of the good reports I had heard. Have been using it since Central Illinois Woodturners Saturday meet last fall and it is working great. Very good buy, especially at $80.
Jeff Taylor -- Bloomington, IN
>I have the same grinder from Woodcraft .. I almost never use the coarse wheel, except when I REALLY need to change the bevel angle or remove a bunch of metal very quickly .. the 120 grit wheel leave a nice surface .. add a little stropping for skews and you are "cooking with gas" ..
mike smith
>When I got my slow speed grinder from Woodcraft slow speed meant no lower than about 1800 rpm. You might want to check out Sears. They now have a variable speed grinder. No doubt, all of them are made in China{probably in the same factory] and quality should be the same. I still tend to burn my tool sharpening so slower speeds would probably help me.
I have two...
Tony Shaftel
>Bought them both on sale. Between them I can sharpen all my lathe tools without having to adjust anything.
Dick Hines
Dick Hines
>Lan, you spend so much time on the road with your job those wheels may last you another 10 tears. You have to use them to to ware the out.
Mike S. told me that you use your tools duel any way.LOL.
Mike Stafford
Mike Stafford
>Lan, it helps if you turn it on when you are sharpening your tools. They will wear down if you do that but it is easier to sharpen the tools......
Lan Brady
>You mean that thing is electic?
I've been turning it by hand!
Lan
