60 degree threadcutter
don lewonczyk
>Can anyone tell me where I can get a 60 degree thread cutter with a 1/2" dia shaft with the cutter head no larger than 3/4" dia? I have a ENCO 60 degre cutter with a 3/8" dia shaft and I have a 3/8" to 1/2" adaptor for a router but it won't work with a set screw in another tool holder I have because its not a compression fitting and the cutter slips inside the bushing. Any help would be appreciated.
DonL
Re: 60 degree threadcutter
>Don Check the MSC catalog or do a google search for 60 degree cutters. I found several the other day but don't remember where it was. I also found smaller size cutters but they were $60 so I didn't order any.
don lewonczyk
>John I did a search on goggle and the results came up for grinding the tips or how to cut threads, mostly for metal work. I'll try again later. Thanks, DonL
>Don I looked during lunch for a few minutes and couldn't find the website I had found. I don't know for sure what I searched under. I think it was 60 degree carbide cutter. I'll keep trying when I get time.
Re: Drill a hole thru the side of the bushing
Al Crandall -NW of Indy-
>I have never been able to find the cutter you describe which is 3/4" diameter on a 1/2" shank. You might try modifying the sleve you already own to allow the set screw to pass through the side and grip the cutter shank directly with compressing the sleeve. Teh problem with the cutter/shank cmbo you want i that the shank will be very nearly rubbing the wood when the final thread depth is reached if the thread is a very coarse one. I have used both 3/8 and 1/2 shanks in my threader, but I just accepted the cuter diameters you have already found.
don lewonczyk
>Al that was going to be my next option, drilling a hole thru the sleeve so the set screw will engage the cutter directly. Teknatol was suppose to have the cutter but for some reason they don't and besides the cost was $169.00 which I thought was a lot of Hardees burgers. Thanks for the input, DonL
don lewonczyk
>Thanks Gary. DonL
don lewonczyk
>John if I use my router like you mounted yours for thread cutting I can use the cutter I already have from ENCO. I have a PC model 690 I think. What kind of mounting frame did you make for your router? I would mount it on the ways of my Nova DVR or I can use the lathes headstock to drive the cutter but like Al Cradel said before it woun't spin fast enough. It would work with hard oily woods but for the run of the mill stuff I have it wouldn't do a good job. What might your take be? Thanks. DonL
>Don I have my PC 690 mounted in a wooden cradle. I just mounted some plywood off center and turned a hole for the router. Then I took them off and cut off half the circle and spaced them about 2" apart. I mounted the top half of the circles using threaded inserts and long screws. I originally had it mounted to my Nova comet which has the same bed as the Nova 3000. It worked great but I decided to build a stand alone bed so the whole unit could travel.
don lewonczyk
>Cool John! Thanks for the picture and the instructions. I was thinking of a half circle cradle out of two inch stock and a steel strap but I think your idea will work better. What did you use to fasten the router to the ways? Did you make a block to slide into the ways of your comet? Thanks again, Don L
>Don I cut the bottom of the router cradle on the table saw until it has a waste area that exactly fits the gap in the bed. Then I drilled the base for a 1/4/x20 carriage bolt. For the clamp I simply cut a rectangular piece that was wider than the gap in the bed and drilled it 1/4". I used a wing nut on the bottom to lock this piece against the router cradle. I did it this way because I thought there might be some reason that I couldn't envision that I would want to move the router.
