OT furnace blower noise
Dick Coers
>Just thought I would pass on some info if you service your own furnace. I had a heck of a noise coming from the furnace when the blower came on. It was just during the initial startup, and stopped when the blower was at speed. Simple fix, replace the start capacitor, nope, still had the noise. Replaced the motor because I felt end play in the bearings when I had the motor out. Nope, still had the noise. Finally a turning friend tell me that he has replaced two squirrel cages in his furnace. That was it! Seems the center sheet metal hub is two pieces stamped together and will start to seperate with time. The furnace supplier asked me if it was "growling" at me, YUP!!!!!! Should have replaced the entire blower since all I didn't replace was the sheet metal housing! Just couldn't imagine that the cage would "wear out".
Re: OT furnace blower noise
How timely.
Randy Johnson Connersville, IN
>When I got home last night my blower was vibrating so loud you could hear it outside.
In my case, the square head bolt that retains the blower on the shaft had come loose and allowed the blower to creep down the shaft enough to get everything off-balance. Pushing the blower closer to the motor and tightening the bolt solved the problem. Hopefully.
common problem
JohnKJordan in East TN
>>...the square head bolt that retains the
This happened to a friend of mine a few years ago. He ignored the noise until it got much worse. By that time, the cage had slipped on the shaft so much it wore down the shaft diameter and the entire motor had to be replaced. I used a little locktite when putting the thing back together.
My sistem once had the same problem. A dishonest (or stupid) repairman looked at it and told her the entire unit needed to be replaced. I tightened the screw and everything it worked fine.
Steven Kubien
>We just went through a bout of no-heat and funny noise from our furnace. Turns out there was water in the motor housing (from the humidifier or dehumidifier). Blew out the water and the line and all was well....until it was also determined that the primary (and possibly secondary) heat exchanger was toast. It was only 16�C in our house yesterday.
Steve Kubien
