Re: Vacuum Pump
Bill Howatt
>I first used an old compressor from a dehumidifier. It worked well and pulled at least 26" of vacuum on a tight system. The weakness is in the pumping speed - it is slow and thus not tolerant of leaks. A small leak can quickly reduce the vacuum. Not all leaks are in your piping, couplers and the bowl/vacuum chuck interface. Some woods have leakage right through the wood (especially end-grain turnings). This can be helped by applying finish to the inside of the bowl before finishing the bottom with the vacuum chuck.
Right now I am using an old refrigeration compressor but it is a fairly large 2 cylinder single-stage unit that was used years ago on a farm to chill a water tank that cans of fresh milk were put in to cool down.
Bill
