Honing Turning Tools *LINK*
Larry Gottlieb
>What buffing wheel compound is best for use on turning tools with a cloth buffing wheel?
I have bars of emery cake, tripoli, red rouge, and white rouge. Are any better than others?
Thank you
Larry
http://webpages.charter.net/lgottlieb2/
Re: Honing Turning Tools *LINK*
Allen Neighbors
>Larry, I have an MDF wheel on the backside of my headstock that I use Emory compound with. It works well. I suppose it would work with a hard cloth wheel, also.
I've heard some say the green buffing compound is best for honing turning tools, but I've never used it, or seen it, either.
Allen Neighbors
I have a hard cloth wheel that I have used the Emory on to buff the shaft of my homemade turning tools when I finished them, and my toolrests after I've de-nicked them. It really makes them shine.
Brian Hahn in SW Wisconsin
>Hi Larry,
I use green chrome oxide bar for honing tool edges. That seems to be the preferred honing compound. I bought the bar at Woodcraft a couple of years ago. I haven't tried honing with the other compounds.
Brian
Jim K in Trappe, PA
>Lee Valley Tools has the green compound - I think it is their own formula. I've never used it.
Leonard Lee, the founder, wrote a book on sharpening, so it may be worth trying.
http://www.leevalley.com/wood/page.aspx?c=2&p=32984&cat=1,43072
>I've been using the Green compound for years. I got it from Lee Valley.
Richard Allen
Richard Allen
>A soft wheel like a cloth wheel isn't going to hone and edge. A soft wheel can polish steel but an edge will be rounded over with a cloth wheel. Hard felt, leather, perhaps MDF, something which won't change the shape of the tool.
There are abrasive impregnated rubber wheels which can be used to hone steel.
You can also use non-woven abrasive belts....
richard jones
>And what are you guys using as a wheel?
Rich in VA
JohnKJordan in East TN
I use the leather wheel that comes with the Tormek - it does a fantastic job. (Leather, of course, has been used for stropping for ages.) The leather wheel has minimal give, made with a thin layer of leather bonded to a hard wheel. I don't think a soft cloth wheel would work well since it might round over the edge. I've seen wheels made from MDF. Even one made from wood should work with a paste compound.
Also, another type of "honing" - between grinds, I hone tools from several to many times with a very fine diamond paddle hone - hold the hone firmly on the bevel between the heel and the edge and hone gently, then polish on the Tormek leather wheel. The diamond hone methond works best with hollow-ground edges.
>Since I don't hone any of my turning tools except my skew I use a flat piece of leather glued to a board. I use this for many of my carving tools as well.
I also have some of the paper wheels that I got from Smoky mountain Knifeworks. I use that for all my knives and carving tools that look like knives. I'll also use it to hone my V tools.
Dick Coers
>I glued up two discs of 3/4" mdf and turned them round. Then I glued on a strip of leather, cutting a long scarf joint at the seam. Works great. Made it 8" in diameter and use it on a slow speed grinder. Of course I go to the back side to hone. Don't want to peel cut that leather back off.
