Thanks and an update
Steven Kubien
>Thank you to everyone's help and suggestions regarding my slipping motor pully problem. I tried to remove the pulley in order to make sure everything was hunkydory inside but couldn't get the sucker off (bizarre that this is slipping and unmoving at the same time). Determined not to give up, I reset the pulley and screw. The set screw is currently Loctited in place and the lathe is running smoother than ever. I did notice a small crack on the lowest step of the pulley and a replacement being looked at.
When the replacement gets here I am still going to have the chore of getting the old pulley off. Any suggestions that won't damage the motor or shaft? I am thinking of making a sort of rip cut across the pulley steps and opening it up like a clam shell. Other ideas are certainly welcome!
cheers,
Steve Kubien
Re: Thanks and an update
Mike Brazeau
>Steve - do you have a puller to remove the pulley?
Steven Antonucci
I've done this many times.
steve antonucci
>I've broken down my Nova 3K many times, and you should be able to remove either pulley with very little effort. In my experience, I've pulled the motor off and removed the hinged cover to have access to the spindle pulley. If you need to remove the motor pulley and it's on really tight, use two screwdrivers with long shaft on either side of the motor shaft to apply steady pressure.
Only time I had the issue was when I got locktite on the shaft...
Steven
>Steve What has probably happened is the set screw has raised a burr when it was tightened against the metal. You can either force the pulley off or you can take a drill that just barely fits through the threaded hole and drill very slightly into the shaft. All it takes is a few thousands of an inch. This will take out the burr and you can get it off.
Nope
Steven Kubien
Re: I've done this many times.
Steven Kubien
>Thanks Steve. It is the motor pulley which is giving me trouble. When I get a replacement pulley, I will try the screwdriver trick, unless I can get my hands on a puller as Mike suggested.
Cheers,
Steve Kubien
Steven Kubien
>Good idea John. I think you may be right about the raised burr.
Steve Kubien
Steven Antonucci
If it's still a problem, try this...
steve antonucci
>Remove the motor with the pulley still on it, and spray some penetrating oil down the keyway. A slight wiggling motion will generally get it done.
I only use the two screwdrivers as a last resort to avoid boogering up the backside of the pulley.
Steven
Re: Nope
Mike Brazeau
>Steve - just checked Princess Auto and they have a Puller in the current flyer for $6.99 that will handle up to a 3" pulley. That flyer ends this coming Sunday. Part no. is 8045965.
Thanks Mike!
Steven Kubien
Dick Coers
>I'm sure that there will be a burr holding on the pulley. The problem may be that the burr is all the way around the pulley. I had to tap a couple of holes in the hub of my furnace squirrel cage blower to get a puller on it. The darn thing wouldn't budge by hand, but it barely took a wrench on the puller to get it off. Good luck.
