vacuum chamber
vacuum chamber
vacuum chamber
Bill Hale / The Wood Spinner
>I want to build a 24" vacuum chamber. I am thinking that a 24" dia. x 24" long flanged steel pipe fitting with end caps may work. My question is will it stand a 28 " vacuum? Every one knows about pressure but not vacuum. I have no idea where or how to get info on this.
Are there any engineers out there that can help me on this? Any other ideas will also be appreciated.
Bill in CG, AZ.
Re: vacuum chamber
Re: vacuum chamber
eaglesc
>IT would depend on the gauge of the steel.
You may as well give it a shot, not like something is going to burst and cause injury.
Re: vacuum chamber
Re: vacuum chamber
Mac
>I see no reason why it wouldn't be all right to use. We put that much vacuum on the bottom of a bowl in the vacuum chuck.A steel pipe, being round,can certainly stand up to stress better than a flat or slightly concave piece of wood.....
Re: vacuum chamber
Re: vacuum chamber
>In my former job, we had a nice vacuum chamber built out of 1/2" lucite that was 24" x 24" x 28" with a hinged top. It routinely took 28-30" of vacuum. It had a routed slot (~1/8" or so) that took an O-ring. We used a ball valve for an inlet as well as a ball valve for the outlet.
Re: vacuum chamber
Re: vacuum chamber
Brian Hahn in SW Wisconsin
>The maximum pressure that a vacuum chamber has to handle is 15 psi. That's the difference between a pure vacuum and atmospheric pressure. Most pipe is rated for well above 15 psig internal pressure. (Most pressure gauges read psig, which stands for psi gauge, with 0 being atmospheric pressure.)
Re: vacuum chamber
Re: vacuum chamber
Bill Turpin in WNC mountains
>Do not under-estimate the crushing force of a vacuum. The surface of this cylinder @ 30 inches of vacuum will have 14.7 psi (absolute barometric pressure at sea level) on it. That is 39,881 total pounds on 2,713 square inches!
Re: vacuum chamber
Re: vacuum chamber
Jerry Klug
>Do you recall seeing Mr Science (or am I telling my age?) heating a 55 gal drum and closing the bung? It rapidly implodes when it cools. If you have the 24" pipe and it is reasonable wall thickness it will probably be OK. If you are going to obtain some new pipe, you would be better off with a smaller diameter and longer length but make sure it is not thin walled. Not only do you have to consider the vacuum pressure but the weld quality on the end caps. Thin pipe is much more dificult to properly weld for a full penetration and uniform weld. Both of those are critical for a pressure weld, whether inside or outside pressure. The steel doesn't know the difference as to where the pressure comes from, stress is stress.
Re: vacuum chamber
Re: vacuum chamber
Norm Smith
>Would the large plastic pipe that is used for water and or sewer lines work??
Norm
Re: vacuum chamber
Re: vacuum chamber
Dale Cook
>Yes Norm, plastic sewer pipe, that's what a friend of mine and myself used. I believe it's 16 inches in diameter and around 2 feet long. He has used his but I haven't used mine. The ends are 5/8 inch thick plexi-glass.I don't know how many inches he's pulled in his.One end is glued silicone on and the other has a rubber seal that is pressed on when it is turned on and it pulls itself tight.
Re: vacuum chamber
Re: vacuum chamber
Dick Coers------WebKitFormBoundaryqFOmq51H3saAc+aC
>If it's really plexiglas, be careful. That stuff acts like glass. Get a stress riser in the form of a scratch or nick and it will break. Score it with a knife and it will snap on that scratch. Polycarbonate/lexan is much better for that application.
Re: vacuum chamber
Re: vacuum chamber
Dale Cook
>Your right, it is lexan.
Re: vacuum chamber
Re: vacuum chamber
>Ok if sewer pipe or lexan will work do I have to worry about getting a hardening compound on the inside and softening the cabinet?
I will likley be using a urithane or a similar material. How thick should the lexan need to be for a 24 in cube?
Thanks Bill
Re: vacuum chamber
Re: vacuum chamber
Carol - now in NC Nebraska
>Shape is an issue here as well, Bill. Cylindrical is much stronger than cube. And easier to come by. So that depends on what you are putting into it.
I once taught a vacuum pressure for woodworking class back in the '90's. We made a small 'pot' with a plastic lid. The purpose was to see bubbles come out of finish when the open finish container was subjected to vacuum. A cylinder about 5" in diameter with a 1/4" thick piece of polycarbonate (trade name is Lexan) for a lid subjected to the maximum vacuum we could produce (25-26"hg) cause the lid to slightly go concave. 3/8" would be better. It didn't break. I had some 3/8 acrylic (trade name Plexiglass) on hand and it didn't break or bend.
BTW the bubble experiment worked very well. One student showed his wife who was into embedding things into epoxy and she appropriated his vacuum rig for herself. He had to build another!
We made lots of vacuum jigs for holding work that was to routed, sanded, carved, etc. We also made vacuum bags for veneering. We didn't do much with finishes but I would like to try sucking India ink into a open celled wood to see how far it will penetrate. Or something with the finest pigments to color wood.
None of this is empirical information, just my experience when teaching the class (for about 3-1/2 years). Vacuum pressure in the shop is a fun and useful thing. I have maybe 3 vacuum pumps at home, one waiting for adaptation to my mini-lathe.
BTW, any chance of getting together for a shop visit while I am on vacation in AZ the end of March? I can reciprocate in August in my shop in Strawberry.
Re: vacuum chamber
my experiences
JohnKJordan in East TN
>The vacuum chamber I used when I ran a small metallography lab was a plastic hemisphere which sat on an aluminum disk with an o-ring seal. A sphere is the strongest of all shapes. I used this to prepare epoxied samples for polishing. I haven't looked, but I suspect a metallography supply company would sell these but they are probably too small for your use. The one I used looked pretty cheap.
Unlike a container with positive pressure inside, a vacuum chamber cannot store the high energies to make it dangerous, and in the event of a rupture, it is an implosion instead of an explosion. (You do have the danger of flying shards.) The biggest design constraint on chamber design is the amount of flexing in flat plates used as sides or ends of cylinders. We used vacuum chambers capped with flat plexiglass when I worked in a research laboratory - if I remember correctly, the plastic was about 1.5" thick for perhaps a 24" cubical chamber. I can send a query to the guy who did all our vacuum work if you'd like more details.
Another "vacuum chamber" I have experience with is the the underwater housing for one of my video cameras. It is rated to 300' below sea level - you can figure the pressures involved. It is made with an 8" pvc plastic tube with a about a 3/8" wall capped with 1" thick flat plastic caps at either end, one of which contains a lens. It uses "X" rings set into a groove machined into the ends for sealing instead of "O" rings. (I had this custom made for a camera so many years ago I hate to remember just when!)
One other consideration on vacuum chamber design - a cylinder is far stronger than a cube or rectangular chamber. A rectangular chamber must be designed carefully to prevent the edge joints from slipping and rupturing.
I was reading some articles and messages on vacuum chambers on pen-turning web sites the other day. A number of people have built vacuum/pressure chambers for stabilzing and casting pen blanks. One I read shared his experience with his plastic top imploding with a loud bang. I remember some nice pictures of small chambers, valving, etc. that may be useful. I can hunt for links or maybe someone else (eagle?) knows exactly where this is.
Re: vacuum chamber
Re: vacuum chamber
>All turners are always welcome in my shop. Be sure to contact before you come as that is about the time we go to Show Low. We are up there off and on all Summer. I have an application for a Craft show in Strawberry but not sure exactly when it is.
Bill
Re: vacuum chamber
restaurant surplus
Ron in Drums PA
>Look for a pressure cooker
Or maybe the pot they use to mix dough and build a cover
Re: vacuum chamber
Re: restaurant surplus
>Hi Ron
Is this a known or just a guess. I would think their pots would be to thin and may implode under vacuum. It does bring to mind their big broasting kettle. It is designed as a pressure cooker so it has a lid, a seal and threaded openings.
I think this or the paint pot may be the way to go.
Thanks Bill
Re: vacuum chamber
Ron in Drums PA
>I had seen an old pizza dough mixer, the bowl was 3/8" thick aluminum and was around 24". It would be easy to make a lid
Re: vacuum chamber
Re: THANKS ALL
>Hey everybody thanks for your input.
Well I decided to go with the paint pot for now. It is a little small but it may work for most punky wood I get. I can loop a Qt jar in series with the pump as protection. Harbor Freight $ 49.99 !
I will post a Pic when I get it done.
Bill in CG, AZ.
Re: vacuum chamber
Re: THANKS ALL
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>If you want the poor mans version for this, here is what I did. I picked up an old well pump tank which had domed ends, and cut one end off with a abrasive blade in my circular saw. Since the tank already had plumbing threads, it was easy to convert to the hose.
I thought about using some kind of gasket, but then ended up just using duct-tape to put the lid back on. It holds fine against 28" hg, which is ~ -14 psi.
I didn't read all of the above post, to see what others suggested, but I assume that this was for speeding up drying. If so, you also need to provide an internal heat source, plus a supply of warm air in, so you can remove the moisture from the evaporation process. It is more involved than one might think.
Re: vacuum chamber
Re: THANKS ALL
>I also just got a piece of 20" Dia. by 30" long heavy wall pipe from a relative. I plan on having a plate welded on one end and a flange on the other. Flange to top should help with boil over.
It will be a while until I get this one done but I will also post a Pic.
Bill
