>Lets start with the Hunter tool & handle level and the center of the cutting edge on center. The tool cutting edge is rolled approximately 45 degrees. Now on the inside of a bowl, is this the best position? If not, then what is the correct position? Cut below center, above center, tool handle down below center, tool handle up above center.
I have used it successfully, but occassionally it will get a little grabby. So I am just trying to find the sweet spot.
>Jake and Ted. There are two things to consider when using the Hunter tool or any of the other round tools. One is the angle that Jake is talking about. This is not particularly critical as long as you are say 35 degrees or greater. The closer you get to vertical the slower the cut and in some case the cleaner the cut. I say some cases because curly wood can react a little differently and require a slight greater or less angle to cut clean.
The other thing to watch for is the bevel of the tool. It does have a bevel. When you are cutting at a steep angle being on the bevel is less critical and it cuts somewhere between a shear scrape and a cut. When your cutting at 35 to 45 degrees if you come off the bevel it will try to grap. You stay on the bevel by both rotating the tool and moving the handle to the right(I'm talking about inside a bowl).
You can also cut with a slightly different area of the tool. To start try cutting at the 9 oclock position on the cutter. Sometimes it might be necessary to cut at about 8 oclock with the cutter a little flatter. This helps stay on the bevel.
When people talk about getting catches with the ring tools it is the same thing. You have a very short bevel on the ring tool and if you come off of it you get the catch.
I cut on or slightly above the center line and usually have the tool rest adjusted to the handle is a little below the cutting edge.
Hope this helps. It's one of those tools that requires playing with. Not as much as the skew but a little more than a bowl gouge.
>I was teaching a glass blower to turn aluminum on the wood lathe today and thought I would try the Hunter tool. It's my understanding that the Hunter style cutter was actually designed to cut aluminum in a metal lathe. I gave it a try. Hand held it doesn't cut any better than a spindle gouge and actually caused more chatter. I did manage to get some pretty clean cuts but I still like the spindle gouge better.
I have no experience with the Hunter tools, but I see that many tuners that I respect seem to love them.
But my question is.. why not use a deep fluted bowl gouge for bowls? It seems the perfect tool to me. Is the Hunter tool really better at turning bowls?
>Dave I agree. I think it is a good tool for endgrain bowls and it can be a good tool for problem areas like the transition from a flat bottom to steep sides.
It's a great tool for vases or vessels that are deep with steep sides. I love it for end grain boxes.
In my opinion it's hard to beat a bowl gouge for turning bowls. You might need to grind different shapes on the gouge but that's what makes it so useful.
The Hunter tool has it's place but it's not an everything tool.
>Dave, my experiences are similar to John's. On a face grain bowl I have found it very useful for clean cutting on a undercut rim or other sharp transitions. Otherwise it's hard to beat a freshly sharpened bowl or forged gouge on facegrain. For end grain it is my "go to" finishing tool!
>Also remember, Hunter tools, other ring tools, and tools of similat design are not necessarily the best tools for bulk wood removal but are excellent for a final finish cut. Rather like a cabinet makers scraper, although "scraper" to me is too harsh. A well tuned cabinet scraper actually cuts, not scrapes.
>Hi folks, my name is Bill Hunt. I do more lurking than posting but I have been testing the Hunter shallow swan neck tool for a couple of weeks. I turn turkey pot calls and have been using the tool to turn the inside the call and rounding the inside to match the outside profile. As I told Mike I need the bottom a little rounded, this is where the screw comes through the shaft, to make the transition from the bottom to the side.This is one of those things that would be a personal modification. These calls are 4"X3/4" deep so i don't have a lot of room. It does an excellent job for what I'm doing. I've also used it on end grain and had prepared stock for our club meeting yesterday for the members to try it,BUT, I got snowed in here in SE Mississippi. first snow since 1993 and it had to come yesterday.
>John - I anticipated you responding and appreciate it. Just thought if I was having a little problem that others maybe as well. I think I must be coming off the bevel, because when it gets a little grabby thats about what it feels like with a gouge. I must admit that I never really thought about riding the bevel with this tool. Thanks.
>on the inside of bowls. I had a shallower bowl that had a slightly undercut curved sidewall to a tight transition curve into the bottom. I was just using the Hunter to get final shape and clean these areas up. I agree, with your comments on the use of a bowl gouge 100%.
