Sanding question for spalted maple
Steven Antonucci
steve antonucci
>Any hidden tips for sanding spalted maple without having the dust muddy up the wood? I hate the grey cast of the piece. I wondered if "sealing it" with laquer will help...
Jump on in folks-
Steven
P.S. I know about the hazards of spalted wood, wear a mask...
Re: Sanding question for spalted maple
JohnKJordan in East TN
>Steve,
I usually seal with several coats of laquer-based sanding sealer (Mylands), or if the wood is really bad, douse it with CA glue.
For example, the object below is one that I soaked in CA glue. It had some horribly soft spots. I actually had to soak it several times while turning to prevent tearout. I also used sanding sealer for good measure just before finishing.
George Van
>Steve, I seal all my spalted wood with Deft, thinned 50/50 with lacquer as it reduces the different hardness areas of the wood. I have not had problems with color change. I have not done it without lacquer as the soft areas sand away too fast and you end up with a rippled surface.I would assume the dust from the dark areas is penetrating the softer light colored areas.
Tung oil sealer
Charles R. Smith
>I've used tung oil sealer (from Lee Valley), and have given it a day to dry before sanding the wood. Having tried it on spalted and punky wood and liked how it hardened the wood surface and gave the wood a bit of a lustre, I've also tried it on non-spalted woods and have appreciated its effect.
Re: Tung oil sealer
Eric Knutsen
>Doesn't the tung oil, "oil" being the key word, blur the spalt lines? I experienced that problem when using Danish Oil.
