>What is the smallest diameter and depth bowl you have cored out using the standard McNaughton coring system? My Nova has a 16" swing and I know the standard kit will allow me to get the biggest blanks, but how small can you realistically go with that kit? Should I also be looking at the micro set?
>If you look at Mike Mahoney's collection, you can see some bowls in his burl sets that may be 2 inches in diameter, and maybe 1/2 inch deep. This is fine for expensive fancy burl or exotic woods where you want to use every scrap. For your standard bowls, I never core anything less than 3 inches deep, or 8 inches wide. It just isn't worth the effort and you wind up with a lot of small bowls that you don't want to sand out because they aren't worth the effort. If you use the mini blades on a 10 inch by 5 inch blank, you can core an extra blank or two more out of it than you can with the standard set. The cutter width on the mini set is 1/4 inch, and on the standard and large sets, it is 3/8 inch. By the time you figure in finish cuts on both the bowl and the core, you lose at least 1/2 inch per cut, and an inch or more in depth (to get a surface for a recess or tenon. You lose more depth on narrow deep bowls than you do on shallow bowls.
