Have a question? Ask Woody!
Band Saw
Band Saw
Dick Hines
Band Saw
Dick Hines
>I was putting a set of Carter roller guides on my band saw this afternoon and when I dropped the rod that holds the upper guides the !@#$%^*()_ steel ball fell out. What a pain in the butt that was. I did find it OK with the help of a old speaker.
What makes this so bad is that this is the second time I have done this. The first time was when I was putting a riser block on the saw a coupkle of years ago. You would think I would have rememberd waht happened thi first time.
So if you ever have the chance to work on the upper guide rod on your bans saw "try" to remember the steel ball. Yopu may not be as lucky as I was and find it both times.
Re: Band Saw
Re: Band Saw
JohnKJordan in East TN
>Ha! While reparing the switch on my Jet 1642 lathe, I dropped the tiny ball bearing from inside the switch. Of course it fell somewhere into 6" of shavings on the floor. I eventually found it with a magnet. But I'm a slow learner - I dropped it again and had to find it again. Shame on me for working on the switch in that spot. I hope I learned my lesson.
