Jet 1642 help needed
Bill McWhirter
>About 5 minutes after starting my year-old 1642 230V lathe this evening, it just quit. It is plugged in, the tachometer readout is still lit and it responds to manually turning the spindle.
I think that the problem lies in the inverter. All of the pixels on the readout are lit (:8:8:8:8:). Pushing the start and stop button on the inverter had no effect.
I unplugged the lathe and let it sit for a while. I blew out the motor and the inverter-they were not particularly dusty. After I plugged it in again, the readout on the inverter came up with an F and some numbers but in a few seconds it clicked and reverted to the all "8's". I have only 4 days before the one year waranty-better than 4 days after it expired I guess.
Has anyone had this problem or know what to do to fix it? The nearest service center is 100 mile away and, of course, it is Friday after closing time. Suggestions would be appreciated.
Re: Jet 1642 help needed
>Bill Check your line voltage and make sure it's within limits. The only problems they have had with the Powermatic lathes at the craft center were because the voltage had dropped slightly below the limit.
Eddie Pacheco; San Jose, Ca.
>Take a look at the label on the motor controller and record the make and model number. Do a Google on this and you may find a site that has a PDF of the manual. There may be a listing of failure or problem codes in the manual. The controller may have failed, but they are pretty bullet proof.
Are all of the connections tight on the controller?
JohnKJordan in East TN
>The lathe may have come with a separate manual for the controller (mine did). Perhaps it has a clue. Unfortunately, the manual is not where I thought I put it so I can't help.
Twice my lathe did that (after a big catch), but it fixed itself after being unplugged for a while.
richard jones
>Bill,
The inverter book that came with my 1642-2 says:
Abnormal display or no display? If yes, then: [check] Cycle power to AC motor drive. then, Is display normal? If no, then Check if all connectors are connect correctly and no noise is present. If that, then: Fix connector and eliminate noise. If not that, then: AC motor drive has malfunction. Please contact DELTA. :(
Sorry for your troubles. Hope it's an easy fix.
Rich
Jeff Rich
>Hi Bill,
I just purchased a 1642 and was told they have a 5 year warranty, you might want to check.
I have only shut down the inverter once with a catch.
I pushed in my stop button and unplugged the lathe for a few minutes, until I heard the relays click.
It worked fine after that but it was initially a shock when it didnt fire right back after the catch.
By the way, I really like this lathe.
Re: Sounds like everything works except the motor.
Al Crandall -NW of Indy-
>I would suspect the on-off switch. I fired up my mini travel lathe yesterday at the woodworking show and it wouldn't run. When I disassmbled the on-off switch it was packed with debris. A thorough blowing out and reassembly cleared up the problem.
Wait A Second!
Barbara Gill, Remlik VA
>Delta owns Jet????????
Re: Wait A Second!
richard jones
>The inverter is made by Delta Electronics, Inc.
www.delta.com.tw/industrialautomation
Not the same pack of dogs as the Delta that we all know and love.........:)
I believe Jet is owned by the WMH Tool Group, which is owned by etc., etc., etc.................... Jet, Powermatic, Wilton..........
http://www.wmhtoolgroup.com/
rich in va
Whew!
>That is a relief. I would hate to think all these Jet owners had to depend on Delta quality control!
Peter Hyde
>I have the 88888 problem with my Leeson inverter and it is always a loose connection on the AC side. Apparently AC tends to loosen connections and it then affects the the inverter, so I was told my an electrical techy. I usually pull the breaker and then check all the screw clamp connections on the AC side and really torque them up tight. It normally fixes the problem for another 6 months or so. I think big temperature fluctuations also aggravate this condition as it happened recently after the shop door was left open all night and the temp went below freezing. As soon as the shop was up to 60� again i turned on the lathe and up came the 888888 error. So i tightened everything and business as usual.
HTH
