Variable Speed Control
Thomas Cline
>Well the speed control arrived from Dealers Electric, got it all wired up....Now how do you program this thing? Please help.....
Thanks , Tom
Thomas Cline
Thanks , Tom
Re: Variable Speed Control
Gary Evans Tallassee, TN
>Hi Thomas,
I'm assuming you have bought a VFD. The two I have were already programmed with default values that allowed operation of the motor. You might want to modify these for your particular preferences, but I haven't seen the need to change mine so far.
What brand did you get? What is the HP? A little more info could be helpful.
Gary
Thomas Cline
>Hey Gary, I bought a VFD by Drivecon. 2 HP. The wiring on my lathe motor has six inputs. The controls on the lathe have a high and low switch, and both the high and low sides of the switch sends 3 wires to the motor. I removed the six wires and placed the three wires from the VFD to the high side on the motor. Do you think this is correct?
Thanks, Tom
Stephen Mushinski
>Thomas,
Not to be rude but you need to read the manual front to back. If the instruction seem greek to you then you might be over your head with the hook up and programming.
Most come preset and in the manual you can see what the settings are and if they match your motor and setup.
I am guessing here, but the motor most likely can run on two different voltages and how the six wires are hooked up will depend on which you have wired it to run on. It will need to be wired for 220V three phase.
The controllers can run on three phase and also can run on standard 220V house voltage. I am guessing that you are running it on 220V home wiring. These are the things you need to be clear about.
As Gary said his come set up and he didn't have to do anything to his. The ones I have used I changed to run on a remote start stop system.
If you are unsure please get someone to help you that knows what they are doing or you just might be buying and new controller. Your question is very vague, with a more direct question it would be might be easier to answer.
Good luck!
Steve
>Hi Thomas,
Is the lathe motor a 3 phase motor? If it was originally running from simple switches off a normal single phase line, then it may not be. If so, the VFD won't do you much good unless you replace the motor also.
If you do have a 3PH motor, then (if you are lucky) the answer to your wiring question may well be in the form of a schematic somewhere on the motor itself. If not, you may have to go to the motor manufacturer's website to find out specifically how it is supposed to be wired. I'm guessing you will end up pairing some of the existing wires in order to get the correct hook-up.
At any rate, I wouldn't put any power on the circuit till you are sure that you have everything wired correctly. You don't want to let the smoke out of the drive or the motor. Electrical components typically don't work as well after you let the smoke out. 8^]
Gary
