Re: Computer Guru Needed, Please... OT
JohnKJordan in East TN
>>...set in the registry which generally
>is not an ideal place for novices to
>start their PC careers.
This is true, but there are utilities that will let you customize things in the OS by changing the registry for you. The one I use is X-Setup by Xteq Systems. Used with Win2K, it shows a "folders context menu" entry that lets you add items to the context menu that appears if you right-click a folder. If something changed this in the registry for you, there's an outside chance it would be visible in x-setup and could be removed.
There are other such utilities, but this is the one I've used for years on a variety of operating systems and I believe it is complete and safe to use. If you chose an option that could be dangerous, the software will warn you. It is wonderful for customizing the OS to do something other than what the all-wise latte-drinking 20-year-old Microsoft developer gurus decided was best for you.
