Turning Air
Turning Air
Turning Air
Bill Clark
>This is another piece of Calif. Buckeye. After cutting the blank from the root ball I thought about it for a long time before deciding what to do with it because of the major bark inclusions. I finally settled upon a natural edge vase shape. I was pleased with the turning process because I didn�t lose any of the wall features in spite of the fact I was turning a lot of air. High speed was the secret to keeping it together. The piece is 7 � � tall, 5 � � wide and tapers down to a 2� base. The walls are 3/16�. I didn�t want to press my luck and make it any thinner. As with my other buckeye pieces it was sealed with shellac and then finished with satin Minwax Wipe-On-Poly. All comments/critiques welcome.
Re: Turning Air
Re: Turning Air
Bill Clark
>Additional views.
Re: Turning Air
Re: Turning Air
Bill Clark
>Additional views.
Re: Turning Air
Excellent work!
Mike Schwing from Md.
>Fantastic work Bill. You should be very proud of this one. Great choice of orientation, great form, and craftsmanship.
Re: Turning Air
Ditto!!!!!
Allen Neighbors
Re: Turning Air
Re: Turning Air
Jennifer@Indy.USA
>Bill this is beautiful! What a challenge it must have been to turn. Just lovely. Thanks for posting it for all to see.
Jen
Re: Turning Air
Re: Turning Air
Cyril Griesbach
>Another spectacular piece. Thanks for posting it.
Re: Turning Air
Re: Turning Air
Bill Clark
>Thanks Jennifer. It was a challenge. One of the biggest problems was finishing the inside. Because the bark inclusions were everywhere I could not use a power sander. I finally gave up on that idea and made clean cuts, shear scraped and hand sanded.
Re: Turning Air
Thanks!
Bill Clark
>Thanks Mike and Allen. As I stated above I spent a lot of time thinking about this piece. I could see I had some nice color and grain but the bark inclusions and natural rim were the challenge. I kept refining the outside shape as I was rough turning and finally got it where I was happy. Unfortunately, none of the pictures really show the full outside profile. Thanks again for the encouragement.
Re: Turning Air
amazing
GaryG in MD
>Bill, This is a real beauty. I'm sure it was a challenge, but well worth it! ...Gary
Re: Turning Air
Scary!
Carol in Illinois
>Wow! That's amazing! I'm amazed that it held together, and I'm amazed at the courage it took to turn it. For our edification, did you do anything to encourage it to stabilize while you turned it? And not to be too ignorant... didja turn the inside or the outside first? Outside? Inside?
Re: Turning Air
Re: Scary!
Bill Clark
>Carol, I've turned a few pieces before that had bark inclusions and found that you have to turn them fast so the tool doesn't have time to find the hollow spot and grab. This was my most dangerous so far. (Always wear a shield.) I turned the outside first and refined the shape. I then taped the outside, put a shop made steady rest on it and started the inside. The tape was as much for protection of the soft buckeye as to hold it together. Buckeye is pretty stable and doesn't tend to crack or flake off. I used a Elbo Tool to do the inside. This gave me more tool stability and lessened the chance of a catch. Sanding was the big problem. I couldn't use a power sander inside because the paper and mandrel would catch at the much slower turning speed of the vase. I had to take careful cuts and shear scrape (at a fast speed) to smooth the inside as much as I could. Then I hand sanded the inside. The outside was power sanded but at a higher than normal turning speed to avoid catching the paper or mandrel. Thanks for the comments.
Re: Turning Air
Re: Turning Air
Bill Clark
>Thanks Cyril. I appreciate the comments.
Re: Turning Air
Re: Scary!
Carol in Illinois
>I had in mind taping the outside to add some stability as you turn the inside. That kinda' made sense to me.
Re: Turning Air
Re: Turning Air
Dawn Adams
>This piece is georgous! Is Buckeye burl fun to turn? Where did you get the wood from?
Re: Turning Air
Re: Turning Air
George Van
>Bill, you have had a lot of favorable comments but I still had to add mine, this is a spectacular piece. The degree of difficulty, tinal form, composition (the upward flow of the grain), and the finish are well done. I am glad you left the thickness as is, it would have been a shame to loose this piece!
Re: Turning Air
Re: Turning Air
Bill Clark
>Dawn, thanks for commenting. Buckeye, when dry is a soft wood. Fortunately it also seems to hold together well and is not brittle. Because it's soft and dry it is quite dusty when turned. I don't know if it's toxic but I always wear a dust helmet. It will scratch easily when finishing so there is no skipping grits when sanding. I also seal the wood with two coats of shellac prior to using a wipe on Minwax Poly.
I bought the complete root ball from a dealer in Fresno Ca. for $200.00. He had many rotten pieces so I tried to select one that was sound. At the time I kicked myself for spending so much money on a piece of wood but it has turned out to be a gold mine for me.
Re: Turning Air
Re: Turning Air
Bill Clark
>Thanks, George. I appreciate your comments. I had a pretty good idea what form I was shooting for when I started turning this piece. As Bill Grumbine would say, "Turn a little, look a little." Well I looked a lot and kept refining and finally reached the point where I said, "That's it," and stopped.
Re: Turning Air
Re: Turning Air
tm
>Thats a beautiful piece.
I'm a big fan of Calif. Buckeye so I read up on it.
Phillip Munz's A Flora of California says that all parts are toxic.
You are wise to wear protection.
tm
Re: Turning Air
Re: Turning Air
Bill Clark
>Thanks for the info TM. I didn't know that. I'll check out the reference. Because my buckeye was turned dry I had dust and small chips everywhere so I wore my Triton helmet. I'm real glad I did after seeing your post.
