Jet 1236 lathe
Jet 1236 lathe
Jet 1236 lathe
bhenr99
>Anyone have a Jet 1236 or know about it? I been looking into var. speeds lathes and just ran across this one and can't find any reviews on it. Thanks for any help.
Bob
Re: Jet 1236 lathe
Good lathe
Ron in Drums PA
>I had one for five years and it served me well
Re: Jet 1236 lathe
good lathe
GaryG in MD
>Bob,
I've used one for three years. It's an inexpensive lathe of good quality. For its size and weight, it's a solid lathe. I turn relatively heavy, wet 12" blanks without even adding extra weight to the base. It lines up very well, and the motor has plenty of power. I have had little trouble from it. (You should never use the banjo extender -- throw it away -- it's dangerous because it will break in half and fall on the floor the first time you use it.)
The main limitation is the 12" size limit. Even though the head stock rotates, you really can't make a finished product with a greater diameter because of the banjo problem (i.e., working outboard). You can, however, rough a blank that starts larger than 12" down to just under 12" by rotating the head stock 135 degrees. It's also nice to rotate the head stock 180 degrees and work off the short end where it's like having a bowl lathe.
Note: it is NOT a variable speed lathe. It is a multiple-speed lathe. The word "variable" is used to indicate "continuously variable", and that's a very different thing.
Perhaps the most frustrating aspect is that the banjo and tool rest get balky after a lot of use because the set screw dents the soft metal of the tool rest post. This makes adjusting the tool rest a somewhat slow, awkward, two handed procedure. If you are relaxed, turning for fun, and have plenty of time and patience, this is not a big deal. If you want to add a couple hundred bucks, you can replace the whole banjo assembly with a much better one from Oneway.
Go for it. ...Gary
Re: Jet 1236 lathe
Re: Jet 1236 lathe
Gordon Seto
>That was my first lathe. The Reeves drive is high maintenance. I upgraded to a Jet mini lathe. The mini is steadier. The new Jet 12"X20" is a better lathe. The electronic variable speed version is coming out soon. It has a starting speed of 270 which is more suitable for unbalanced blanks.
The 1236 was not a bad lathe; but not a good one. Most of turners who own this model upgrade to better lathes in a matter of when.
Harbor Freight has an almost identical clone except color usually sells for $180.
Gordon
Re: Jet 1236 lathe
Re: Jet 1236 lathe
Eric Knutsen
>I recently acquired a Jet 1236 with speed control. It is smooth, sturdy and strong enough to handle just about anything I've put on it. As far as the banjo is concerned, I was told to get the Delta 46-711 12-Inch Tool Rest Base off of Amazon for $60. So far, so good. The Jet tool rest base wasn't rated very high. The ONLY negative thing I would have to say is the position of the motor and its air intake. It sits directly behind the headstock and does sometimes interfere with the stock when using a spur center. As the wood turns it can clip the motor housing. Otherwise, no complaints.
Re: Jet 1236 lathe
Reeves drive
Ken Grunke from SW WI
>Agree with Gordon on the Reeves drive, it needs to be cleaned and lubed quite often and it's a bit of a pain because the headstock cover needs to come off--a couple of the screws are inconvenient to get to.
The swiveling headstock tends to go out of alignment so every time I use the tailstock to drill something, I have to loosen the headstock swivel lock and knock it back into place. No biggie, there's enough play there to be able to get it right on the mark.
Definitely not a lathe for a pro or serious turner, but pretty good for the casual turner.
Re: Jet 1236 lathe
Re: Reeves drive
Barry Elder
>I agree with everything above. Plus, on Dec. 28th my 1236 tried to take my arm off. To make a long story short, the on/off switch had pretty much filled up with sawdust which when mixed with the condensation inside became quite hard and interfered with the operation of the switch. While doing another task I leaned against the lathe and it started and laid open part of my right forearm. There was a piece of wood in the chuck and it had no mercy. I believe that you learn something new every day, and this one I didn't enjoy. I have now healed enough to make piles of chips again, but remember that damn switch!!
Re: Jet 1236 lathe
motor location
GaryG in MD
>Very true. The simple solution is to use a chuck-mounted spur center. I have an inexpensive chuck that I switch back and forth between a screw center and a spur or steb center. This moves the wood out beyond the motor housing. ...Gary
