Anyone make their own buffing wheels?
Steven Antonucci
steve antonucci
>I have an endless supply of t-shirt, and I'm debating making my own buffs. Anyone ever try this?
Wife sews, and it's just a big ball of rags, right?
Steven
Re: Anyone make their own buffing wheels?
Lan Brady
>Steven,
some pros and cons:
pro- t-shirts are made of combed cotton and you have washed them so they are very soft and make great polishing rags.
con- t-shrits are jersey knits, most of the buffing wheels are woven fabric.
On a woven fabric, You will notice that yarns break off as you are buffing. When using a knit fabric, the yarns will just unravel and wrap around the shaft. They actually could get long enough to grab the piece from your hand.
If you think like I do, you are still going to try it, so good luck. Lan
Steven Antonucci
Am I that obvious? :-)
steve antonucci
>Of course I will... but I figured that if someone already did it, I'd learn from their mistakes. Looks like I get to be the trail blazer...
Steven
I've seen people use denim from jeans
Clem Wixted
When I had a heart attack ...
Allen Neighbors
>in 2005, I spent some of my recuperating rest periods in my recliner, cutting out circles of material. I cut 8" diameter circles, using a small plate for the size. I made the Tripoli wheel, 3" thick, out of felt. I made the White Diamond wheel, 1.5" thick, out of Cotton Denim/Polyester mix. I made the Carnauba Wheel, 1.5" thick, out of 100% Cotton Denim. I made just a polishing wheel, 1" thick, out of 100% Cotton Flannel. My choices of material were just whimsical thoughts, that have turned out to be near-perfect.
I stacked the disks, drilled a 1/2" hole in the center, CAed an appropriate length of 1/2" i.d. CPVC pipe in the center, so it would slip over my mandrel easier. They work like a charm! I have an extended mandrel that is mounted on a 1/2hp 1725 rpm motor.
If I were to do it over, I would make them all 3" thick. That is perfect for just about anything.
I think the round buffs would be a little more complicated to sew up, just because I don't know the "twist" formula. I don't have the round buffs. But one day I plan on sitting down with a few rounds of fabric and trying to figure it out. :)
Re: I've seen people use denim from jeans
Lan Brady
>Clem,
Denim is an excellent choice.
It is woven soft cotton.
Lan
See post below from Allen
Clem Wixted, Jonesboro, AR
>Thanks Lan,
I was given some excellent tips and instructions from Allen Neighbors a while back. He explains below how he did his.
I cut out a pile of denim circles from old jeans and proceeded to put the pile in a "safe" place. As soon as I find it I'll complete the project. He was right, it took a while to get the pile cut out :-)
Clem
eaglesc
>Russ Fairfield mentioned he had made his own on in a post on the IAP years ago.
I believe he used denim
Another method is to turn two ends out of a hardwood that will fit into a Lambs wool paint roller.
Make the ends to fit the M taper and live center of your lathe
The length of the roller allows you to use different sections with different compounds.
Bill Crommett
>It has been forty years or so, but I found it fairly easy to just tear a bunch of denim squares, punch a hole in the middle and bolt the squares between two pieces of plywood and cut the circles on the band saw. You don't want to try this with a four tooth skip blade, and use flat head stove bolt that will sit flat on the bandsaw table. I used these buffs with glue based buffing compound to texture carved waterfoul wings.
