UltraTouch insulation? *LINK*
Carole Valentine
>Anyone used this? I am considering it because I can get r-21 with 5.5" insulation and because of the soundproofing qualites. Any negatives you can see?
UltraTouch Spec sheet
Carole Valentine
Re: UltraTouch insulation?
Jennifer@Indy.USA
>Looks interesting Carole. I've never heard of it before, but I'll be anxious to see what others say. How does the price compare to standard insulation? I imagine it's higher, but the other benefits may outweigh a higher price.
Jen
Mac
>Carole, You can get R19 out of standard 6" fiberglass and they do make a denser one that gives more.Why go to the extra expense for an unknown when you can get proven for less?
robo hippy
>I haven't seen the cotton stuff, but did see some wool insulation. I like the idea of natural fiber. I was told that they soaked it in boric acid (something they do to the bamboo flooring and ply) so the bugs don't want to eat it. If my shop wasn't already insulated, I would try it.
robo hippy
HarryB
>Carol, the stuff looks good but is there local availability? You may pay a premium for the material plus a shipping charge from Arizona.
And...have you considered foam insulation? The kind that is sprayed right between the studs and then foams to fill the cavity. It looks good when I've seen it on "This Old House" and probably installs faster that the batt material.
Harry
Carole Valentine
>My builder used it in his shop and really likes it. He gets it from Charlottesville and is going out there to get more for another job. I particularly like the idea of it for the the walls of the compressor/DC room because of it's soundproofing qualities of their "Insulator" product. We do pay a bit of a premium for it since it is made on the West coast. I think the cost differential was close to $500. We talked about the foam, but that was so long ago that I can't remember why we decided against it.
Carole Valentine
>Good point, Mac. I check to see what's available in fiberglass although I like the idea of insulating with recycled "bluejeans" cutoffs. LOL Maybe my builder prefers it because he doesn't have to put up with itching and breathing problems of fiberglass. I can sympathize with that because I helped put the insulation in the ceiling of my current shop. It was awful stuff. To work with.
Jeff from MA
>I am looking at an insulation project in my house. I just got two quotes, one for close cell and one for open cell.
The closed cell is $1.04 per square foot, 4 1/2" R-30. The open cell is about $0.88 per square foot, 8 1/4" R-30.
The open cell insulation has very good sound absorbing properties. Both products go in clean, with no toxic out gassing. Installation time for my entire attic is less than 1 day.
Gil Jones on Lake Seminole GA
>Carole, that is a new one for me, but it does sound interesting.
I am wondering why the R19 and R21 are both the same except for their weights.
Luck,
Gil
Carole Valentine
>Density, I think, Gil.
richard jones
>C,
Flame spread is OK, the borate additive is interesting to me, as we have a borate wood-treating plant here in my county...........
The company has gone to the trouble/expense to have an ICC ESR done, so they have done their legwork/homework.
Check with your local building dept. for vapor barrier requirements. If you installed house wrap, then I wouldn't think you would or should use any other vapor barrier. I would certainly allow that here in my county. Don't want any moisture getting trapped between two barriers...................
I would contact some actual end-users of the product, i.e., homeowners, and see what they say about it.................your supply house should be able to furnish you some names..........
Rich
Re: UltraTouch insulation? *LINK*
George Van
>Hi Carol, a product I would consider is Applegate blown cellulose insulation for walls and ceilings. It is the best product we could find for actual R value performance in our area (presently �22 degrees). I must mention that foam was not available so we did not research this product. Our first thought was the old cellulose insulation that settled but if you go to the site you will find this is totally different. When they spray the walls all corners are filled as well as the voids around wires, pipes and duct work with an adhesive additive (starch) so that it will not fall to the bottom of the stud spacing. On the ceilings, cathedral and flat it is sprayed in blanket fashion also filling all voids. It is guaranteed not to settle. Even with the wind chills at �44 today there is not any cold air blowing through the outlets or around the windows. The only one who seems to dislike this product is our propane supplier, they cannot believe how little fuel we use for the 4600sq/ft living space. My shop has this also on the ceiling as I already had the walls finished with R19 glass. It is also very efficient but you can tell the difference in the walls. We have checked the levels of the insulation in the attic and the walls also and there has not been any settling. That is on a wall that has only the vapor barrier as the paneling has not been applied so it is easy to see. They do have an extensive network of installers. The wall application was more expensive than the R19 if I bought it at HD and installed it myself, the ceiling was $.01/sq./ft less. Sorry for the long voice but I am convinced this is a good product as it saves me money every year. I know of seven houses that have been insulated the same way after seeing ours and they too are happy. Perhaps this is overkill in your area but fuel is expensive everywhere.
Applegate Insulation
Open cell
Jorge Castaneda~Downeast Maine
>absorbs water, don't use it.
Jorge
