Re: Hunter vs Eliminator
Mike Jones, Redding, CA
>I bought the Mega Eliminator while at Portland AAW Symposium last fall and I love it. The Mega, with 1" shaft and balanced handle allows you to get way out over the tool rest. Contrary to what some have said about the milled flats on the shaft, the tool is just as round on the bottom as the Hunter and can be rotated easily...you are not at all restricted to the 45 deg. cutter position, but those flats are very helful when cutting deep and blind.
From very aggressive, ribbon throwing, hoggin out material, to very light clean up cuts, it's a sweet tool. I don't know about the Munro, but I suspect that the carbide cutters are very similar for all three tools.
The Eliminators, in each graduated size is a bit spendier, but the length and heavier diameter shaft selection, would (and did) sway me.
Hope this info is helpful...
