Re: Trying to get the hang of it
JohnKJordan in East TN
>>I wish you could see the post you are
>responding to when you type.
Mark,
One thing you can do while posting is select the message, hit Ctrl-C to copy, click Post Response, then click in the Message box and press Ctrl-V. This dumps a copy of the message in the box that you can refer to and delete later, or leave a short portion as a "quote" to help a reader follow a thread with several branches. (I like to use the old BB ">" convention to show quoted text.)
Another method if you have enough screen space: you can keep the message displayed and open up the Response dialog in a separate window. Right-click on the Post Response link and choose "Open in a New Window", or the equivalent in your browser and OS. A big advantage of this method is it lets you review the entire thread if needed while typing. I always use this method since I use dual monitors and have plenty of screen space.
As for the catches, it's hard for me to make a guess without seeing what you are doing, but I used to get major catches when I tried to cut with the wings/sides of the gouge - it helped to swing the handle around until I was cutting more with the tip than the side. It also helped to "aim" the top of the flute more or less in the direction I was moving the tool. After some experience, it got easier to cut more with the sides under some conditions, for example on the outside of a bowl with the handle very low.
The scraping cut, sometimes called shear scraping if I am picturing what you are doing correctly, is great for light smoothing, but not much good for major material removal. (And it's hard on the razor-sharp cutting edge.)
