Still doing things the hard way - Bowl #3
wilbur
>So I thought I'd post a picture of my third bowl. It's rosewood, the finish kind of sucks because I was experimenting with various types of waxes, and it was another survivor of my blank-orbiting experience. I still seem to want to do things the hard way, as this bowl also turned out to having fairly vertical sides, but not as much as my last one.
I'm not sure why I don't do easier shapes. There's something about vertical sides in a bowl that just appeals to me.
Rosewood bowl
Re: Still doing things the hard way - Bowl #3
Steven Antonucci
My early bowls had similar issues...
steve antonucci
>If my interpretation of the picture is accurate, it looks like there are a bunch of tool marks in the interior. It is something that later on you will look at and wonder how you missed.
Most new turners don't realize that turning a bowl like this probably takes 3 hours- 15 minutes to cut the bowl, and the rest for finishing. Sanding is not fun, but dramatically increases the final products quality. If it still has a foot, I'd remount it and sand it until the rings disappeared.
Steven
P.S. Rings are probably compression rings from the heel of the gouge- you might want to shorten the bevel for a finishing cut...
Looks nice to me, Wilbur
>I suspect that your concern with "vertical sides" has more to do with what your eye is used to seeing than with any absolute right or wrong to it. Speaking for myself, I like to see curves in transition, either static or accelerating.
What kind of rosewood is that by the way, and did you turn it green or dry?
>There's nothing wrong with vertical sides it's just harder to turn because of the transition between the sides and the bottom. Vertical side bowls are more functional and probably more traditional.
It looks like a very nice bowl to me. I agree with Steve it does look like there are some lines in the transition point. That doesn't reduce the functionality at all just takes away from the beauty a little.
Cyril Griesbach
>It's a very nice bowl and one you can be proud of. When Steve says to shorten the bevel on your gouge for finishing cuts I don't think he means to regrind the whole gouge profile. Simply round off the sharp angle from the bottom of the gouge where the angle goes up to the tip. It's this sharp angle that may be causing the brusing he mentiones. As you continue to sharpen the gouge this sharp angle will again develop and then you can just round it again.
Beautiful Bowl #3.
Allen Neighbors
>I like the shape of this one... it would make a nice salad bowl. Beautiful wood, also.
Re: Looks nice to me, Wilbur
wilbur
>This is East Indian rosewood, and it was a dry blank. At least I think it's dry. When I bought this blank it was covered in wax, but once I got past the wax, it felt dry to me.
Re: My early bowls had similar issues...
wilbur
>Regarding the tool marks, what's the best way to get rid of them? Is sanding the only method? I would have tried using a scraper, but I didn't have a scraper of a suitable shape that would allow me to get deep enough into the corner, which led to my recent question about what scraper shapes people used.
Steven Antonucci
In order of "degree of difficulty"
steve antonucci
>1.) Sanding- easy, but time consuming. Anyone can go through the grits...
2.) scraping- relatively easy, but will risk tearout if done wrong. Still a bunch of sanding follows
3.) cutting- hard to master, even harder to explain. I have an "inside" bowl gouge with a much steeper nose than my standard grind. Practice. Also, releiving the heel to shorten the bevel will help with bruising...
Steven
