>My question is the extra expense for a Jet mini vs. worth it. I notice you are restricted to so much speed on each pulley range. Is the range on each pulley that much that it is worth the cost. Even with the vs. you still have to keep changing the belt for each range. I can't find any info that shows the RPM for the different steps on the pulley with the vs lathe. Thanks for any help.
>I had never used a lathe without variable speed until at the end of last year. I really missed the ability to change the speed easily. I don't know what the difference is in cost but if you can afford it, get it.
>I wouldn't be without variable speed. But it depends on what YOU turn as to what YOU want or need. You don't need the variable speed much if all you're going to turn is spindles.
>I think it might depend somewhat on the things you turn.
I have used my Jet mini only for small diameter spindle turning. I generally leave the mini on one speed, usually 1800. If I were turning larger diamter things like bowls or boxes, I would miss the variable speed that I constantly adjust on my larger lathe.
>I'm with John. On my mini lathe I almost never change the speed. I also find that the non VS version has more power on the lower rpms. On my big lathe I wouldn't be without VS if I could help it.
>I have used the Jet minis with and without the variable speed. As mentioned, I found the lathe with VS was easily stalled when turning a larger item at lower speeds. This became a source of frustration. I enjoy the VS on the powermatic.
>I love variable speed on my big lathe, but I also own the non-variable version in the Jet mini. The straight version has much more torque than the variable speed version, and you will notice it immediately if you are roughing the outside of a bowl blank which maxes out the capacity of the mini. It is disconcerting, really. I have stalled the motor while using a 1/4" bowl gouge on the variable model. If the blank is out of balance and wants to toss the lathe around, you are no better off with the variable because both lathes have a minimum rpm of 500. It is too fast for roughing and too fast for sanding. As good as the Jet lathes are, my opinion is that Jet missed the boat with the variable speed model when they didn't give it a minimum rpm of around 250. I like my straight version better.
>I only have one lathe - the JET VS mini/midi (here is the break point between mini, midi, "regular", large and DAMN! ?). As a newbie, with only the face plate, live center and spur drive, turning spindle type stuff, I found it comforting to Go Slow. Later found that, in general, "slow" makes things harder. The high end of the Low RPM Range, about 1800 rpms, is where I now play most of the time - and things are a lot easier.
Then, like you probably will, I got a scroll
chuck (SuperNova2- and the head stock
spindle adapter - for those who like details) and started thinking BOWLS. Then the variable speed - and a foot pedal on/off switch - came in handy.
A 9" diam. x 6" long chunk of wood, especially wet wood, even bandsawn to roughly round
can be a scary thing when spinning at 1800 rpms - or even 600 rpms. With the VS, I can start at the lowest end of the Low Range and dial up the speed 'til thinks start vibrating more than I'm comfortable with. As the roughing to round progresses I can dial up the speed 'til the wobbling starts then back off 'til it stops. As things get more symetric I just dial up the speed again.
Now if I had to keep moving the belt from pulley to pulley I'd probably have skipped bowls and still be turning just spindle type stuff.
For really unbalanced blanks I found that adding a foot controlled on/off pedal was nice. Step on the switch, cut a little before the WOBBLE! started getting scary and step off the foot switch. With the right toe tappin' rythm I could work the rough blank almost continuously.
Also found this "dead man's switch" handy when things go wrong. It's comforting to know that when all hell breaks loose, that you don't have to reach over and turn off the lathe - when you regain consciousness.
>Robert, I think they're talking about the single-pulley (regular)version lathe versus the Multi-pulley version. I don't think he meant the 'electronic variable speed'.
I'd like to find that post from John Lucas... guess I'll do an archive search. Thanks for posting! :)
>to no avail... I've searched through all of John Lucas' posts from Jan 07 through Jan 08, and I couldn't find it. Do you know something that will help me find it?
>Allen I don't even remember what I did. I will look at the power supply I have left over and maybe it will jog my memory. I don't know if I put that in my Jet mini mod folder.
>As noted by a couple of other people, the variable speed model does not have much power in the low range. It seems to be a choice between variable speed and power. I opted to spend about the same amount as the variable speed mini would cost and buy the Jet 1220. It gives you a 3/4 HP motor instead of the mini's 1/2 Hp motor and you pick up a couple of inches in swing and length. At close to 100 lbs it is portable, but not as easily picked up as the Mini. You also get a 9" tool rest as well as the short one. I am happy with mine. I think that it is a good value. I bought it for a second lathe that I can transport if needed.
I love the variable speed on my big lathes, but the speed controller and motor on the Jet mini are just plain frustrating for me. Or to be more succinct, I think they stink, big time. Why? Lousy torque at all speeds. Poor speed control. No low speeds. Not reversible.
>if it's reversible or not. I may be way off base on this, though, because I don't even have a Jet.
My mini lathe has a 1/2hp motor that I installed on it, and the motor was reversible, but it was necessary to go inside the motor box to switch two wires around. Our good friend, Eddie P., helped me with a schematic that showed me how to wire in a double-pole, double-throw switch. (Then I had to install a set screw in the chuck.) :)
>The variable speed Jet mini uses a DC motor. DC motors are intrinsically reversible and it is very easy to do -- simply change the polarity of the drive power.
