What are some things you can't live without?
Steven Antonucci
steve antonucci
>Now, as a woodturner for almost 10 years, I realize that not every list will be the same. It depends largely on what your goals and aspirations are, as well as the things you make. I see the "New Turner posts" all of the time, and it got me to thinking- "What does someone really need?"
Lathe and tools- check.
But how about the not so obvious?
I couldn't live without(not technically, but having used one wouldn't ever want to go backwards):
a chuck
compressed air at the lathe
my library of books and magazines
And probably a litany of other things, but let's hear what else everyone considers "part of the basics".
Steven
Re: What are some things you can't live without?
Don Orr
>If you're talking strictly turning related;
Good lighting-my eyes are getting old.
Comfortable shoes to stand in for extended periods.
Padded mats to stand on with those comfortable shoes.
Safety gear !
Dust collection-I like my lungs just the way they are. ( Such as it is.)
Convenient, fast sharpening setup.
All my little gadgets and doodads within easy reach.
Shopvac, broom and dustpan.
I'm sure there's more, but I'll look forward to seeing what others have to say.
>Good question Steve
I'd have to say books and magazines, not just woodturning. When I have an good idea nothing stops me from creating it. I use whatever tools I have. This was true when I didn't have anything and still true today when I have most everything.
Bandsaw. If you took away just about everything but the lathe and bandsaw I could still do a lot of what i do today.
My hand tools. With a handsaw, plane, and some chisels and carving tools I could and have made similar pieces to what I do today. Not nearly as fast of course.
My workbench. I would have to say that almost all projects either start, end or spend some part of the time on this bench. It's nothing fancy, a solid core door as the top, 4x4 frame and a good vise with bench dogs. That may actually be the most used item in my shop.
Bill Clark
>In addition to what has already been listed, a good sanding system and abrasives plus a lot of old clean T-Shirts to cut up for wipe-on finishes. This post is a great idea and it will be helpful for new turners.
Calipers
Ron in Drums PA
>Need them for boxes.
And a steady stream of great looking wood.
Mark Williamson
>My grinder is nice for the big stuff but as I use mostly dental picks for my lathe tools, I would have to say my dremel tool gets the most use! The flex shaft has been VERY nice! And I think the oneway jaw chuck is indispensable! Aside from that, I am most thankful for opposable thumbs! Without them, the world would be a different place all together! LOL
Stuart Johnson
>The lathe and tools are a given. The one thing that has been a life saver or at least a turning saver is Wood Central. I doubt if anyone that visits on even a semi regular basis has ever asked a question, requested help or wanted opinions that went away unsatisfied. Books, magazines and videos are all good but you are out of luck if you don't understand something. Stuck on a tool grind, need help with a shape or how to photograph it, just ask and you will get an answer.
eaglesc
>Tablesaw
CA glue
Any kind of wood it doesn't matter as long as the colors/grain is different
Beall Collet Chuck or equivalent for drilling accuracy
Diamond Stones(I like sharp tools, I don't use a grinder)
Rick Allen
>Top of the list is an accomplice. Not someone who will get out of your way but someone who enables you in woodturning. Someone who will look at your work and see the joy and excitement reflected in your work.
Next would be safety equipment:
Hands on training which teaches, among other things, how to turn wood safely.
Face protection
Lung protection
I also think that wood is important. I learned a lot about woodturning from working different woods. Some woods are forgiving of sloppy technique. Other woods will require good technique. When you go back and turn the forgiving wood with good technique you will discover that even forgiving wood responds better to good technique.
Notebooks to draw and write in. I will often draw something 10 or more times before I understand what I need to do for the object to be successful.
Peter Charles Fagg (UK)
>Electricity!
In my shop the other night and the power went leaving me in total daerkness!
Peter.
Robert Henderson
>Wood Central!
>Lathe and tools.
Chuck (and Jacobs chuck).
Sharpening set up.
Mat.
DC system.
Lighting.
Mostly, the LOML.
I'd miss any of the above, but most especially the last.
JohnKJordan in East TN
>Sharp tools. The Tormek makes this easy for me.
Plenty of time. Retirement helps more than a little bit.
All of my parts. Safety equipment and knowledge rule.
A supportive wife. Better than an unlimited budget.
Steven Kubien
>I managed to trip the breaker for my lights which also had my shop-vac going a couple of weeks ago. It's tough getting around in my shop at the best of times but when I've been roughing bowl blanks on my bandsaw and there are large off-cuts and blanks all over the place...well, getting to the garage door was a challenge. Good thing I am lighter on my feet than I look!
Steve Kubien
Steven Kubien
>Aside from the obvious lathe, tools, chucks, sharpening gear etc...my bandsaw and a small set of calipers set to the size of my 3" faceplate ring. I use them all the time and they really save a bunch of mucking about. I would also be pretty screwed without WoodCentral! Oh yeah, without free wood, this would not be happening.
Great topic.
Steve Kubien
Mike Jones, Redding, CA
>My chainsaw. No way could I afford to buy all the wood that I want to turn...chainsaw equals free wood.
robo hippy
>Variable speed, a bigger bandsaw, my grumpy old kitty cat (anyone else seen 'the attack of the innocent kitty' on You Tube?), and more tools. I find it hard to walk through a catalogue, or tool store and not see something that I just can't live without.
robo hippy
or perhaps as Brent said perhaps you should change your name to Robust hippy (slightly less than 3 months away).
Charles R. Smith
>Reminds me of a discussion my wife was engaged in many years ago. A bunch of young wives were discussing the most important thing which they added to their kitchen. The discussion centred on such things as their microwave, gas stove, or convection oven. My 85-year old aunt quietly said that the best thing she ever added to her kitchen was running water.
OXYGEN-H2O-FOOD-WARMTH-ETC.
Ken Oakley-Starry St. Cloud, Fla
Dick Hines
Dick Hines
>I know this is going to sound sappy but, I couldn't live with out my wife backing my hobby. She puts up with me spending tons on money, time in the shop when I should be doing things arouind the house. She even helps me at shows that I do about 4 of a year.
Sure would be lonesome around with out her support.
Mark Williamson
>AWWWWWWWWW! Ain't that SWEEEEEEEEETTTTT!! hehe
Sorry I couldn't resist!
