electric forced air heaters in your shop?
Atwerz
>Interested if any of you have heaters in your shop 1000 feet or so. Would like to know the brand, source, level of satisfaction, and will it keep your butt warm when its 20 degree temp outside.
Re: electric forced air heaters in your shop?
portable type NM
Atwerz
>My shop is small, about 300 SF, but I use a small "barn" heater. The one I have is really old but it continues to work. You can buy them at Lowes and probably many other places. Then newer ones have Tip" protection so that is you turn it over it stops (I think). I do not leaving on all the time. If I want to work in the shop I go down 15 to 30 minutes early and turn it on. I would think a couple or three of them would work for you.
I also have a propane heater that bolts onto the top of a fuel tank. Its about 45,000 BTU's and will run you out in a matter of minutes. I used to turn it on during the warm up period and then turn it off, but I have not used it in a year or two.
I wish the thermostat on the unit were more accurate and sensitive. IF you turn it on, it runs until it is way too hot, if you turn it down it gets way too cold. So, I just use it as an on off switch. If it would hold the temp closer to the desired temp it would be nice.
bowlman
>My shop/studio (too cluttered to be considerd a REAL "Studio") is a 2 car garage that has never seen a car inisde in 24+ years. So I'd estimate it a 500 square feet. Well insulated. Went to Meijers and purchased a ceramic heat that has tip over safety, hi low settings and an oscillating feature. Cost $40. Temps here have been in the teens or lower at night. Shop in the morning is usually 50 or 55. Then I plug in and turn on the heater (Sits on top of a CD player speaker. In an hour its up to 65 at the opposite end of the shop. Once I actually start turning I can turn it down. The DC and other heat producers augment the body heat being generated so I'm nice and comfy. Best $40 I ever spent.
Mark Williamson
>I have about the smae size shop, the two car garage that has been about 20 years since it has seen a car as well. I have been thinking of getting one of the ceramic heaters to keep on low at night. I heat with a woodstove but that much space take a while eto heat up in the morning! Twice this week I have gone out in the morning and my bottle of wood glue has been frozen! Is this a good idea to run a ceramic tower heater over night on low? I have dirt floors right now and an open spot that I could set it and not catch anything on fire. How much does that effect your electric bill?
Mark
>Mark I simply can't afford to run heaters all the time in the shop. M shop probably doesn't get below freezing but gets very close. What I got tired of was glues and finishes that were too thick due to the temperature so i bought a metal office cabinet and insulated it. Then I put a light in the bottom and a thermostat in the top. It keeps all my paints, glues and chemicals at 60 degrees. That has been a godsend especially with my epoxies.
Mark Williamson
>I gotcha! That is an excellent idea! I will try that
bowlman
>Mark,
Since I just got the heater, I'm not sure what the cost is. But as I said, I only run it to take the chill off the air. After that, my natural insulation takes over ( I'm just a smaller version of Bill Grumbine). Anyway, since my house is all electric, and when it was built I paid to have it built with thicker walls so I could get added insulation (like R36 in the walls, and R46 in the ceilings, plus we just installed insulated vinyl siding) I have a pretty low electric bill compared to others around me. Like I said, even when its below zero, the shop rarely falls below 45 or 50. Hope this helps.
Texian
>750 sq. ft., yes, would have to go look, big box store, 100%, yes. But not portable. There may be alternatives to portables that would work for your shop. You might want to describe your shop area and see what suggestions appear.
Jesper, Denmark
Re: Not electric, but.......
Jesper, Denmark
>I have a 1000 sq. ft. shop/garage. It is rarely really cold outside here, probably 15�F and a stiff breeze is the worst. We are on a co-generated district heating system, using 200�F hot water to provide the heat.
The shp has a water coil with a fan, which is thermostatically controlled. it ios set to just above freezing, and very seldom runs. When I do go in the shop to do something, I turn the thermostat up to 60 or so and run it for maybe 30 minutes. At that time the chill is out of the air and the RH has dropped a bit and the temperature is in the 50's. I find that with a sweater or two, that is just fine as long as you do something.
I expect the electric heater will do the same and be quite cheap to buy and run as you really do not need to run it for very long.
Stuart Johnson
>You might want to check over on the message board. There has been a thread over there about shop heaters. Ellis posted a link to what looks like a pretty nice setup.
