Silver Solder Question
Clem Wixted
>I was given a short piece of what I was told is silver solder to use to mount a tip on a turning tool.
I have an electronics background and it is "flexible" just like regular solder used in electronics and looks the same.
I thought silver solder would be quite stiff and "bright."
It walks and sounds like a duck. Can it be silver solder? :-)
Thanks,
Clem
Re: Silver Solder Question
>I have soft, medium and hard silver solder on hand. They are all much much stiffer than regular solder. Whether that's true of all silver solder I don't know.
Dale Johnson
>yes it can be silver solder. it comes in different melt temperatures so you can assemble. you will need a flux made for silver solder. when you apply the flux it goes on wet, dries with heat and remelts when it is ready for the solder. do some reading on it.
Dale Johnson
>part two. yes, silver solder should be stiffer and if i remember right, the silver solder should have a yellowish color to it. it has been a long time since i used it. if the solder you have looks like silver it probably is not.
Dale Johnson
Barry Turner
>You may have a type of silver solder that is designed to melt at lower temperatures. I had some once, and it was very similar to regular solder in stiffness and was used with a liquid flux that was brushed on.
Bill Turpin in WNC mountains
>Silver braze with 35 to 45% silver is a quite stiff wire, usually about 1/16" diameter, uses a borax/boric acid white paste flux. It melts around 1450�F. it has a tensile strength of � 90,000 psi. It is a silvery copper color.
Sil-phas is a hard stick with 6 to 15% silver. Melts above the stuff above. It is self fluxing on copper to copper. Does not like steel.
Silver solder (7%)is alloyed with tin, so it is bright silver colorfor several years. It melts at � 450�, used with a liquid acid flux. Its characteristics are close to lead solder. It has a higher tensile strength than lead.
Bill in WNC mountains
expecting 8" snow tonight
Thanks for your response
Clem Wixted
>I think that this piece is regular tin/lead solder or equivalent.
I tried to find a spool of solder I picked up at a yard sale last summer. I seem to remember that it indiated it was a plumbing solder and also the word silver was part of it's name.
Is there a such a thing as plumbing silver solder? Is it strong enough for soldering a tip to a tool for turning? I assume it would need a special flux available at a plumbing supply. How about a big box store out in the boonies?
Clem
