200+ woodworking book reviews
Epoxy for filling voids
Dale Long
>As a frequent viewer, this site has helped me greatly. My deepest thanks to all of you. My question is this. Which of the epoxy systems,two that I am aware of are West Sys. or System Three, would be the best choice for me to use for filling Knot holes, voids, etc.in my turnings. The two I mentioned seem to be very similar in my reading of their properties. I would be adding color and solids to try to get the most natural appearance possible. Tips on colorants and solids to use would also be appreciated. Thanks much for sharing your collective knowledge and help. Dale
Re: Epoxy for filling voids
Barbara Gill, Remlik VA
>For large voids I have always used the West system. I use finely ground coffee as a filler. If I want the fill to be black, I use the black color West system sells. If I want brass color, I use key filings.
Allen Neighbors
>Dale, I haven't ever bought either of these you mentioned. I've always just used the 2-ton epoxy that is sold in Walmart. I guess it's because I think I don't use enough to justify buying in larger quantities.
I crush natural, unprocessed turquoise for fillings in darker wood, and Maryland Club (cheapest I found) coffee that I've run through the Vita-Mix to powder it, and brass key filings, also.
Rick Allen
>Both are high quality marine epoxies. Either one can be adapted as a filler.
I like West System with the slow hardener. That provides a nearly gin clear epoxy. The other hardeners from West have an amber color. I figure if I start off clear I can control the color. For filler I use a white filler. Again this is to control the color of the finished product. I like to use bright vibrant colors and using a brown filler would tone down the brightness I am looking for.
To help prevent color from migrating into the wood I "wet" the wood. This is where uncolored epoxy is applied to the wood which form a barrier to the colored and thickened epoxy which is added soon after.
If the colors you are looking to use are black or browns then the color of the epoxy (hardener) and filler isn't going to be an issue.
Be aware that one of the things you are paying for with marine epoxy is strength. That is one thing which is never needed in filling voids in a bowl. This is to say that there are many cheaper filling substances which have the attributes which you are most interested in.
I use epoxy because I have become familiar with how it works. Knowing what the outcome is likely to be is more important to me than the cost of the product.
I started using epoxy because I thought I knew what I was doing. There was a learning curve for me with success and failure along the way. If I were going to start over I would use one of the polyester resins as the void filler. I suspect that the learning curve would be about the same as it was for me with epoxy.
Mostly I use West System,
Gil Jones on Lake Seminole GA
>Sometimes I use clear Cast'n Craft polyester resin. For color I use ground coffee (unused), brass grindings (used to use key filings, but they are mostly aluminum and steel now). Crushed turquoise is a beautiful color in wood.
Gil
Carole Valentine
>Hi Dale. I generally don't fill voids because I think they are part of the character of the wood, but that's a personal preference. When I do, I use the plain old 2 part epoxy (the kind in two connected tubes) from the hardware store. For coloring, I have a set of 12 small jars of powdered pigment in various colors with which I can achieve a very nice match by mixing and swirling various tints through the epoxy. I did this not too long ago on a natural edge cherry goblet that blew out a bark inclusion on the side, and unless you knew exactly where the patch was, it was very difficult to find. I'm sorry that I can't remember the brand of the pigments. The label on the box is gone. If I think of it I will let you know. I got them from Michael's Craft Store. They come in flat, pearlized and metallic.
Most clear slow-set epoxies will work.
Brian Hahn in SW Wisconsin
>I've used the two-tube 2-ton epoxy that is available everywhere. It works well.
Both System West and System 3 are marine epoxies and come in larger quantities. Both are good. I use System 3 because that's what's available locally. The advantage of marine epoxies is they remain slightly flexible so they will accommodate the normal seasonal changes in the wood.
5-minute epoxy never gets really hard, so most people avoid it.
Dick Hines
Dick Hines
>I don't fill knot hole if they go all the way through. If there is some bark inclusion I will fill that with turguoise or lapis chips. When sanding the chips useing Abranet seems to work better than sand paper.
Dale Long
>My deepest thanks to each of you who responded to my question. I value each of your responses and tips. Dale
moisture and movement
>marine epoxies are engineered to provide the best movement in a moist environment. these are the two factors found in most wood turnings.
over time, some of the non-marine epoxies will pop-out or separate from the wood.
