Tool gloat!
Tool gloat!
Tool gloat!
Steven Kubien
>Thank you to everyone who offered advice and comments over the past couple of months regarding my seemingly endless chainsaw questions. My new Stihl MS390 got broken in, briefly, this afternoon and I am very happy with it. I only put a 18" bar on it even though it is good for a 25" but I figure I will end up getting a spare bar so I can cut this saw out, if I need to. Hopefully it will get a good workout this weekend or next.
Again, thanks everybody.
Steve Kubien
P.S. Do all Stihl's have that throaty, growling voice? It sounds mean and authouritative.
Re: Tool gloat!
Steven Antonucci
Make the second bar the same size
steve antonucci
>Otherwise, you'll need twice the number of chains.
Figured you knew that, but said it anyway.
Steve
P.S. I love my Stihl and it's growl. Just like a Ford sounded "funny" to me when I had my Chevelle, so do other saws...
Re: Tool gloat!
Re: Tool gloat!
JohnKJordan in East TN
>I put a 24" bar on my big chain saw specifically because I needed to cut some large trees. (the biggest I've cut up with it was a 4' white oak).
One thing, the longer bar makes for a unbalanced chain saw - it's extra work handling an already heavy saw. A heavy, unbalanced saw is significantly more dangerous than a balanced saw. I would not get the larger bar unless I really needed it. You can cut almost everything with the 18"
I agree to get a second bar exactly the same as the first. If you ruin one, you can swap and keep on cutting. If you cut trees and get one jammed, you can remove the saw head, mount the spare bar and chain, and keep on working. If you rotate between the two bars and several chains, everything will wear out evenly.
Check the local farmer's co-ops and dealers for seasonal sales. One co-op here has a biannual 50% off sale on chains.
As for the "throaty, growling voice", I've never actually heard my saw clearly - I never start it without ear protection. I use the combo hard hat, face screen, and ear protection sold by Stihl and others. I bought two for when I have a helper.
Also, check into kevlar chaps. They are only about $50 and have saved people from bleeding to death.
BTW, I highly recommend a book called The Good Woodcutter's Guide by Dave Johnson. It has sound advice from an experienced woodsman about caring for and using a chain saw and how to stay alive while keeping all or most of your parts.
JKLJ
Re: Tool gloat!
Re: Tool gloat!
Steven Kubien
>Thanks John and Steve about the "same sized second bar" advice. That was what I was kinda thinking but I like the ability to pull a larger bar and chain if the need arises. Yeah, I suspect the 18" will do most of what I need.
As for hearing protection...yup, I've got my earmuff style ones with me at all times. I only had them off the first time I started the saw. I had to hear it 'for real'. I like loud noises such as rock concerts, jet airplanes, Harley's etc.
I've got full face protection as well. Do you think it makes a difference whether it is a clear plastic shield or one of the mesh-like ones you described, John?
Chaps are coming this weekend. My little brother has a spare set. Only damage to them is a little bar oil staining. Oh, and that certain stench that only little brothers can make.
Thanks for the tips and advice.
Steve Kubien
Re: Tool gloat!
Re: Tool gloat!
I think the plastic will work fine. I like the helmet/face shield/hearing protector all in one since it is so convenient to carry and put on. It also forces me to wear a hard hat when I might be tempted to leave it at home occasionally. I HAVE had limbs whack me hard on the top of the hard hat. (And I do have a tiny cut in my chaps that I have no idea how or when it happened.) I wear steel-toed work boots as well - got mine at Walmart.
The makers of the wire mesh face shields recommend wearing safety glass underneath the mesh. I often don't since the mesh will stop everything except for fine dust. I do wear glasses when generating a lot of fine sawdust.
