what I do
JohnKJordan in East TN
>MMWW, (and anyone else interested),
I'm sure there are several good ways to proceed. I'm certainly not an expert turner but I have made several hundred wands. I can tell you my methods and some reasons why. (This is for one-piece wands)
-----> Start with a blank 3/4" to 1" square by 12" to 1" long. Most of my wands are about 10"-11" long. Straight grain is better since burl or wild grain will tend to flex more and break. Hard, tough, fine-grained wood is easier to work with but anything can be used. Small tight knots are ok but large knots, cracks, shake, and other defects can make it difficult to complete the turning. If there is some interesting figure or tight know in the wood, try to position it on the handle end rather than the spindle end. Wood should be dry since green wood will often flex too easily.
-----> Optional: Trim off some wood on the shaft end as in the photo below using the bandsaw. I make several shallow cuts in from the side then rip strips from the sides. Besides making the turning quicker and easier, the little strips of exotic woods are useful for other things (and kids love them). Don't trim off too much in either dimension since that will limit design flexibility while turning.
-----> Mark the center of each end of the blank. In hard and/or brittle woods (dogwood, bloodwood, osage orange, oak, bubinga, pink ivory, etc). I make a small hole in each end for the points of each center. Without this hole, brittle wood will split under compression from the tailstock, especially as the shaft is turned thin. When making wands in batches, the hole will simplifies mounting the next blank. Instead of using an electric drill, I keep a small gimlet stuck to the side of the lathe with a magnet. You can find gimlets at Woodcraft and elsewhere - I find them convenient for many other tasks such as starting holes for screws.
-----> Optional: Turn a short Morse taper on one end to fit the lathe (as in the photo below). Why? This will allow the blank to be jammed into the lathe spindle shaft and act as a chuck. You can also simply grab the end with a chuck but I don't like to do this for two reasons: One, the chuck is large and gets in the way when turning the end. This may mean you have to allow a little extra length in the blank for clearance, causing more problems with flexing. Two, you have to be more careful around a spinning chuck. Three, on a short mini lathe, the chuck takes up space that might keep you from turning a longer spindle.
Note: I found it very important to grip one end securely in a chuck or jam chuck. If turned entirely between centers, the shaft can flex more easily on the two pivot points on the ends. If one end is held securely in a chuck, that end cannot easily flex so the strength of the wood minimizes flexing in the entire shaft. Another reason for chucking at one end is it simplifies the final step of parting off both ends.
To turn a short morse taper, I start by measuring the exit diameter of the morse taper on my lathe by measuring the burnished line on the widest point on one of my drive centers.
Mount the blank between centers. I use a 1/2" Steb Center to drive the blank. Turn a short cylinder (about 5/8" or so) on one end with a parting tool to that exact diameter. Then I turn a slight taper on that short cylinder. The first few times, I took a second measurement from the shaft of the drive center as mentioned above, but after that I just eyeballed it. If I accidently get it too loose, I just cut it a little longer. Since I was making wands in batches (I made about 75 for the last book release), I made a little brass go-nogo gauge to make things quicker.
The taper does not have to be perfect. If the wood is soft, it will give some when pressed into the lathe spindle. (One hint, it is easier to get a tight fit on very hard wood by cutting a small relief groove in the center of the short morse taper. I can make a diagram if needed.)
-----> If using the jam chuck method, force the blank snugly into the lathe morse taper. I simply tighten up on the tailstock, then back off a tiny bit. (TOO much compression force on the blank while spinning may cause it to flex.) If using a conventional chuck,
-----> Round the blank. Since it is small diameter high speeds are OK. Use whatever sharp tool feels comfortable (small roughing gouge, spindle gouge, skew) but since the shaft is getting thin use a minimum amount of force. I start by rounding the thick handle end then the thin shaft.
-----> Turn the shaft thin before the handle. This tends to keep more strength in the better-supported end and keeps flexing to a minimum. I primarily use a 1/2" skew chisel but a gouge will also work. Razor sharp tools are a must.
-----> Support the thin shaft while turning. The most effective way (for me) is to cup the fingers of my left hand lightly around the spinning shaft to support it while holding the cutting tool entirely with my right. The left hand travels with the tool to support the shaft always right behind the cut.
This method requires a bit of practice. Some things I do: rest my left arm or elbow on the top of the headstock housing. Grip the tool close to the cutting end with my right hand and support the handle if necessar by pressing it under the right forearm. Use my left thumb as needed to steady and push the cutting tool as needed - this is especially handy when using a skew on grooves or cutting tricky curves.
I read this good advice in one of Raffan's books (I think): if your fingers get hot from the friction, you are using too much force! Back off, slow down, sharpen the tool.
Note: there is come controversy about the safety of putting your hands in contact with spinning wood. I consider this reasonably safe since unlike a larger shaft or bowl, the very thin shaft will easily break. The biggest hazard might be wearing loosely fitting sleeves with the left arm draped over the work, especially when using a chuck. Another reason not to use a chuck.
-----> If the thin shaft begins to flex and vibrate, back off and change something. Things I try: loosen or tighten the tailstock. Speed up or slow down the lathe. Sharpen the tool. Try a different tool. Cut in a different direction.
Occassionally when planing with the skew chisel I run into a situtation where out-of-roundness, say from irregular hardness in the figure, can cause the skew to bounce on the bevel instead of cut smoothly. This is bad on a thin spindle since unlike a heavier piece, each bounce flexes the shaft regardless of how firmly you support the tool. In this case, the thing to do is to cut with the point at the heel of the skew instead of part way up the cutting edge as normal. This peels back the rough wood and lets the bevel follow smoothly behind.
Occasionally you will have a disaster (small catch or something) that causes the entire shaft to bend like a bow. This is more likely with soft or flexible wood, especially if the wood is not quite dry or the grain is not straight. If this happens, I stop the lathe and bend the shaft back into place. Sometimes, I'll just smack the shaft lightly near the center with the handle of the tool while the lathe is spinning. It may take several tries, but eventually I hit exactly the right spot and the shaft snaps into true again.
-----> After thinning the shaft most of the way, I rough out the handle, then finish turn the shaft, then finish turn the handle. I shape the very end of the handle last, leaving 1/4" or so to drive the wand while finishing.
-----> Sand and apply finish. I like to use beeswax for a soft finish, escecially on cedar. Mylands friction polish is great for a high gloss and very quick.
-----> Part off the tip end with a skew chisel while continuing supporting the shaft lightly with the left hand. The skew will make a far cleaner cut than a parting tool, leaving the end ready for hand finishing off the lathe. Back off the tailstock a bit if there is still pressure.
-----> While continuing to support the shaft with my left hand, I reach under with the skew and part off the handle end. Sand and finish each end by hand as needed.
As for design, it's wide open! I tend to try something new and wild on whim, repeating designs I find pleasing. I sometimes use a wire to burn accents in groves - that can look good not only on light woods but on darker wood such as walnut. I've done some multi-axis that were nice. This summer I started making some with distressed handles which were very popular - I scratch the handle with a sharp tool, dig grooves with a small gouge, smack dents into the side, use a coarse wire brush to dig into soft grain, etc., then sand lightly
before finishing.
Two-piece wands, say with a dark handle and lighter shaft, are a bit easier to turn but take a little longer. I've made a few with a contrasting light ring between the handle and shaft of a darker wood.
If the wand is for a specific person, I try to make the handle fit the person. I made up a bunch of different styles of handles on short scrap wood to let people try them for fit.
That's all I can think of at the moment. Some day I hope to take photos and write up a short article with these steps. I have lots of photos of past wands if anyone wants to see them. Most have been posted here before and are in the archives, but I noticed recently that some of the archived photo links have been corrupted.
