9/16" chuck for old lathe
chris krohn
>I have a fairly old small lathe that has a 9/16" spindle bolt coming out of the head stock. Does anyone know where or what I can do to either get a chuck that size, or use an adapter to use standard size chucks that I have. I am getting so frustrated with this issue.
Re: 9/16" chuck for old lathe
Phil in NJ
>Oneway advertises that they'll custom thread an adapter for you for their chucks.
Phil
Bart Rhoads
>Any machine shop can make an adapter to fit any lathe to any chuck.
Chris, now's the time for a new lathe! :-)
Clem Wixted, Jonesboro, AR
>Get a 1"x8 piece of all thread or a bolt and have someone tap it 9/16. If they do it on a metal lathe it should run true.
Bill Hale / The Wood Spinner
>Unles the lathe has special meaning to you don't bother. If it does have a special meaning put it on a shelf as a display. At 9/16 it is not only small but so are the bearings. Fix one thing and another will go.
Spend your dollars on something newer, either used or new but get a name brand.
Good turning and be safe
Bill in CG, AZ.
John Leonard
>Chris, I have a 9/16 insert for a Nova chuck that you canhave if this helps. Email me at jdl38@dishmail.net if interested. John L.
