Re: Variable speed adjustment
gtwilkins
>Thomas,
You have to match the variable frequency drive (VFD) to the motors horsepower. Basically the VFD takes single phase power (either 110 or 220 volts) and electronically powers the 3 phase motor.
http://www.leeson.ca/Html/Products/adjspeed.htm
I used a Speedmaster SM Series VFD and a 1hp 3 phase motor on my Shopsmith before I ungraded my lathe.
With the VFD I used I had to purchase an on/off push button switch and a controller to adjust the speed. It did take me a while to figure out the programming for the VFD but it was fairly simple once I got started.
I then had preset speeds, or I could manually ramp up the speed, dynamic braking so I didn't have to wait for the lathe to coast to a stop plus it gives you more torque at lower speeds.
Hope this helps, Trevor
