>In the last couple days I have used bactrial masks when turning on my Midi. They are easy to put on/off and do not restrict the viewing area. The metal band on the nose makes it fit comfortably. Anyone have an idea of the dust collection properties of such masks? Our health is primary and the thought of wearing a big mask is just not acceptable in a Midi/Mini application. Any thoughts? Philip
>Any type of mask is better than no mask at all. I don't know much about the actual filtration qualities of the different masks. I don't like the idea of a big cumbersome mask either. I confess that I only use a thin 25-cent dust mask, usually only when sanding. There are similar masks that are much thicker with an upper and lower strap that are used in health care settings. These are much more effective and may be what you are describing. Adequate ventilation in the shop can also be effective at controlling dust, but that's a lot more difficult in Winter weather. The fact that you only have a midi/mini lathe doesn't really excuse you from wearing proper dust protection. Small lathes can generate quite a lot of very fine dust during sanding operations. It's the really fine dust that does the damage, as I understand.
>Make sure that any dust mask you use is rated N-95 minimum and preferably N-100 which is equivalent to a HEPA filter for small micron and submicron dust particle size. The dust under 10 microns seems to be the most problematic, particularly stuff that < 3 microns.
I don't believe the mask you described is adequate unless it is labeled N-95 or greater. But as someone previously stated, any mask is better than none.
