How do I avoid this?
Scott Hurley in N. VA
>I was trying to color this little hollowform with aniline dyes, and I can't get the dye to take on the widest part of the form, leaving a streak around the middle. Did I not sand enough in that area, or did I sand too much? Is there a way to prevent this problem? I've seen many hollowforms with a uniform color, but I can't seem to produce it. Any help would be appreciated. Thanks.
Scott
Re: How do I avoid this?
Phil in NJ
>I'm assuming this is an end-grain turning?
Looks like the dye is being absorbed readily in the end-grain.
If so, you might want to consider a coat of a sealer (shellac, etc.) before the dye...
Barry Turner
>Side grain and end grain absorb dyes and stains at different rates. If you study your form closely, you will find that due to the shape of this vessel, almost all of piece is end grain, except for that narrow band that did not absorb the dye. Only this narrow band is truly side grain. This is probably part of the problem.
Sometimes, if you sand with dull paper or with the lathe running too fast, you can burnish the wood. This can also interfere with dye absorption. When you sand, slow the lathe down and use fresh, sharp sandpaper. If your fingers get hot, you are probably sanding too fast or applying too much pressure.
Another thing I like to do is when you finish sanding with your finest grit, stop and raise the grain with a wet sponge and warm water. After the wood dries, sand again with the finest grit. If your lathe reverses, try sanding in both directions. Try these tips, then apply the dye again. Good luck.
Mike Schwing from Maryland
>Yup, as has been said - the dye soaks into the end grain at a different rate than the long grain and this piece is short on long grain. A sealer coat of shellac would go a long way towards helping this. What I'd do, however, is to spray it with an alcohol soluble dye rather than brush or wipe it on. Sprayed as a mist that dries nearly instantly as it touches the surface, you can completely control the absorption. You could do this with an airbrush or a spray gun.
>I've used an airbrush to add extra dye to the light areas. on flat work you simply sand the endgrain to a finer grit but I find this is very difficult to do on round work because you just can't control where your sanding accurately enough.
Thanks
>Thanks for all the quick responses.
Scott
