Lighting for Oneway Lathe--Long
Dennis in Southern Oregon
>Wally Dickerman posted a request yesterday for ideas on lighting for his upcoming OneWay lathe. I can't seem to recover that request from the archives.
By coincidence, I bought a halogen lamp a couple of weeks ago from Enco a couple of weeks ago and had just gotten around to mounting it yesterday. After reviewing the options, I decided to mount it directly to the headstock of my OneWay 2436. This turns out to give great flexibility in the positioning of the light and is out of the way. It allows the light to be used with either inboard or outboard turning. The light was (is?) on sale at Enco and is their model MFG 7240, Catalog #505-002. The mounting was done as follows: I cut a 3" x 3" x 1/4" piece of steel plate. I drilled four holes in the plate to match the holes in the base of the lamp, and tapped them to accept 8-32 machine screws. Then I drilled two 1/4" holes about 2" apart in the middle of the plate. Then, I drilled two (undersized) matching holes in the top of the headstock and tapped them to accept 1/4"D x 1/2"L flathead machine screws. The 1/4" holes in the mounting plate were then countersunk with a 1/2" bit so that the flathead screw did not project above the mounting plate.
The following pictures show some of the possible positions of the lamp that can be obtained.
Re: Lighting for Oneway Lathe--Long
>Another position of the lamp
>This shows an example of the lamp positioned for outboard turning.
>A close-up of the mounting arrangement.
Ed Wujciak
>Prompted by some positive comments on this site, I also bought one of these and mounted it in a similar way on my Nova 1624. Previously I'd used a Luxo lamp, but with a 100W bulb it was too unpleasantly hot to get near when used close-in as it had to be used. I tried a CFL and solved the heat problem, but it wasn't bright enough or "sharp" enough. The Enco light ($100 on sale delivered) throws a smaller spot a fair distance (like a lower-tech dental light) so you can position it a few feet away and get a bright, sharp spot where you want it. I like mine and recommend it to others. I figure it's the last lathe lamp I'll ever need.
Stuart Johnson
>How hot does it get? There have been a few stories about near fires from halogen lights.
Ed Wujciak
>It's sealed against sawdust and does NOT get hot. Seems totally OK to me. It's a 12v bulb with a transformer in the base. I unplug it between sessions because the transformer stays warm otherwise.
Wally Dickerman in Arizona
>Looks like a good system. Thanks for posting. Interesting that it doesn't get hot.
Wally
Allen Neighbors
>I've been all over Enco and can't find it. Can you check it out... maybe I've transposed numbers or something. The MFG 7240, Catalog #505-002.... neither will come up with the lamp.
Thanks for posting this... that light is really nice (beefy and long enough), and you've done a good job mounting it. I'd like to do the same.
Never mind, I found it. # 505-0002
Allen Neighbors
Carole Valentine
>I don't understand how it cannot get hot. Hot is the nature of the halogen beast. Is there a heat sink of some sort? If it is sealed against sawdust, that would mean there is no ventilation, resulting in further heat buildup. At the worst, I would think that would shorten the life of the lamp. Help me out here...I would like to have one of these but my experience with halogen/heat has been rather scary.
Ed Wujciak
>Kinda warm, yes. Hot, no. You can always touch it with your hand so it's not dangerous.
