He said he wanted a big rolling pin...
>My BIL wanted a large rolling pin (he is a chef) with handles. I typically turn tapered ones (because I like mine :)). So, I figured I'd give it a shot. This is it - all glued up and ready for an oil wipe (mineral oil). Grain has been raised on the maple a couple of times, then sanded.
Re: He said he wanted a big rolling pin...
Don in Central Illinois
>That should keep his employees in line.
Steven Antonucci
Better not let your sister see that!
steve antonucci
>you might end up an accessory to a crime...
S
Allen Neighbors
>That's a nice, large, rolling pin. You mentioned tapered "ones"... did that mean tapered handles, or tapered rolling pins? If it's tapered rolling pins, tell me about them, you've got my curiosity up.
Also, I'm curious if you used a kit, with bearings, or if you just used some sort of axle without bearings.
My granddaughter wants me to turn her a rolling pin, and I haven't a clue. :(
BTW - What is a BIL???
The MountainMan
Brother-In-Law
Ron McKinley
Re: Brother-In-Law
Barbara Gill, Remlik VA
>That reminds me of the 6 rolling pins I turned from walnut for a woman back in 2006; I didn't have time to air dry the wood. What diameter is the body? She wanted walnut since the tree came from her yard. I cut 3" billets on the sawmill and then rounded them. I soaked the blanks for about 1 week in denatured alcohol and stood them on end while they dried, rotating about every week.
She too wanted them to be large; I think the diameter was around 2 1/2" and the lengths around 23".
Re: Directions for Allen and tapered pin
>Kit - why use a kit?
My tapered rolling pins are usually either hard maple, cherry or some other close grained wood. Take a 24" or so piece of wood that is about 2-3" square. Turn between centers. The area of greatest diameter is about 12" or so. Taper the "handles" on either side so that they are a comfortable "handle" (about 4" or so). Taper down to about 1 to 1 1/4". Raise the grain after you get it smooth and sand again. Then part off and sand the ends.
The rolling pin that I did for my BIL is more traditional.
1) Rough out a 16-20" piece of wood (3" or greater) between centers and square off the tail stock end.
2) Turn a tenon on the head stock end
3) Mount tenon end in chuck.
4) Finish off what was the tail stock end and drill a 2" deep 1/2" hole in this end. Bring up a cone center to fit in this hole.
5) Part off the cylinder at the desired length on the head stock side. Square the parting cut as you go. Figure that this has to go in a drawer or cabinet so if you figure on ~9" for handles, the cylinder has to be on the order of no more than 12-14".
6) Reverse the piece in the chuck - I usually use a large rubber band to "cushion" and protect the roughed cylinder. Drill out the other end 2" deep 1/2" diameter hole.
7) Turn a jam fit tenon at ~ 1/2" to fit in the drilled hole.
8) Finish turning the cylinder between the jam tenon and a cone center. Raise the grain a couple of times before the final sanding.
9)Turn handles - I usually rough out two small 2" cylinders that are about 4-5" long. I mount them in a chuck and drill a 5/8" hole through the handle body.
10) Turn a jam tenon in the chuck that is 5/8" to fit in the hole and bring up a cone center and finish turning the handles. Make sure that the handles are the same length.
11) Take two pieces of 5/4" wood that are about 8" long. Rough them out between centers. You want about 1 1/2" of 1/2" in diameter on one end. The body of the "handle shaft" is just under 5/8" so that it will turn smoothly in the handle. The 5/8" portion is as long as your handles. You want a "button" or knob that is greater than 5/8" on the other end.
12) Wax the 5/8" handle shaft - make sure that you don't get wax on the 1/2" portion or the glue won't stick (DAMHIKT).
13) Part off the shaft at the desired length.
14) Test fit the handles on the handle shafts.
15) Glue together. I usually use Titebond II, which is water resistant.
Re: Brother-In-Law
>My diameter is just over 3".
Thanks, JL... Much Appreciated !! :)
Allen Neighbors
Re: Brother-In-Law
>Thanks
Thanks
