A55 Smoothing Plane
jumbo jaw building question???
keith zimmerman, Normal, IL
>I am going to build a set of jumbo (cole) jaws for one of my Talon chucks and have found all the parts. The body of the jaws will be made from a sheet of phelonic I have and I plan to use rubber stoppers to hold the bowl.
My question is: what size rubber stopper should I use? They range in size from 8mm to 55mm in diameter. I am thinking that 10mm would be more than adequate for my purpose. These jaws will be used on a Jet mini, so the jaws will only be about 8" in diameter.
keithz
Re: jumbo jaw building question???
Steven Antonucci
8" Jumbo jaws?
steve antonucci
>Why not make a "stepped" jaw out of MDF? Basically a circle cut in quarters with some accurate drilling for the screws? probably get away with no more than 3 steps and no bumpers...
Steven
Rick Davenport
>You can get a bumper replacement kit for standard cole jaws.
Oneway uses black rubber, which I have, but I'm thinking those square red ones they have for vicmarcs might be better.
Check out Craft Supplies, I believe they stock both.
R
Bill Clark
>I have both and prefer the Vicmark red square bumpers.
