Chuck "washers"?
Chuck "washers"?
Chuck "washers"?
>How many of ya'll use "washers" (the plastic things that fit between the chuck adapters and spindle end) when mounting your chuck?
The thread about stuck face plates a while back (November) got me thinking. Should I just mount one on my spindle permanently? I usually alternate between using a drive center and using my chuck. I'd rather not try to keep track of a small plastic washer if I didn't have to.
Re: Chuck "washers"?
Mike Schwing from Md.
>I used one, till John Jordan told me to "just don't screw the thing on so tight". Stopped using it and never had one get stuck again thereafter. Just turn it gently till it seats and leave it there is what I learned to do. It never spun off either.
Clem Wixted
>I have a PM3520A and I use a plastic washer I cut out of some kind of plastic bottle that seemed fairly consistant in thickness. I used a punch set to cut it out and the ID threaded snugly over the spindle threads and resides near the headstock on the unthreaded part of the spindle. I just leave it there and it doesn't unthread itself while turning when there is no chuck on the spindle.
I'v never had a stuck chuck. However, I have had a chuck come loose (didn't dismount) when I turned the lathe off and slowed the lathe by holding the handwheel.
Clem
Stuart Johnson
>I have a few face plates made out of 1-1/4 x 8 nuts and washers that done seat properly unless I use two washers. I do not have problems with them.
Brian Hahn in SW Wisconsin
>I use very thin washers made from an overhead transparency sheet and color them so they are easier to find. The commercial washers are way too thick and soft for my liking.
I'm not sure how much they help. My old Conover lathe really liked to hold onto the chucks and face plates and I've had some pretty tightly stuck ones even with the washers.
Larry Bisbee
>I leave my plastic washer on the lathe and never remove it, whether I'm using a chuck or not. I don't have it permanently attached and have never had a problem or lost one, but I do keep lots of spare washers just in case. I wouldn't mount a chuck or face plate on my lathe without one.
>I don't use them unless I have to. On my new powermatic the spindle is a hair longer than some of my chucks and faceplates. they sent me 2 of the nylon washers to use but I decided I wanted a more firm seating so I built a metal washer than goes on and takes the place of the 2 nylon ones.
Mark Wollschlager
>At home and on most machines I do not.
I clean the threads and the contact surfaces of the spindle and chuck ( or faceplate).
I make sure the chuck is snug before powering the lathe up.
That seems to be the ticket for me.
On some old powermatics our club uses that have a small surface behind the spindle threads, it is recommended that we use a washer.
I do if there is any wobble, sometimes it helps.
Its too easy to introduce runout in the chuck with a washer ( or dirt/debris ).
Mark.
Steven Antonucci
Never have
steve antonucci
>Nova lathe, Nova chuck, never been an issue. Also don't use the lock screw on the chuck insert to booger up my threads on the headstock...
Steve
Never use them
Ron in Drums PA
>Did you every remove a chuck from the spindle then replace it later on?
Did you then notice a slight wobble?
That's what happens when you use a plastic washer. You just can't get the chuck to seat the same way every time.
A better material to use would be a sheet of copy paper.
have used 1/8" tempered masonite for years
robert davis
Bill Hale / The Wood Spinner
>I turn either between centers or with a jaw chuck and never use a washer. When the jaw chuck goes on I lock the head and use the bar to set it. Just a thump with the hand and it will come off the same way.
Good turning and be safe
Bill in CG, AZ.
Wally Dickerman in Arizona
>I have never used a chuck washer. A lot of years ago I had a badly stuck faceplate and went through what Ruth Niles went through some time back. I determined at that time that the reason for stuck faceplates and chucks is that they are screwed on loosely, and when the lathe is turned on they slam on so tightly that they become very difficult to remove. Just screw on the faceplate or chuck to a snug fit and you'll never have a problem.
The weight of a loosely fitted chuck plus the weight of the bowl blank can cause it to be unscrewed in an instant if the lathe is stopped quickly.
Wally
robo hippy
>I have been using a washer for years, one of the plastic ones from Craft Supplys. I have never had a stuck chuck or face plate since. As far as not putting it on so tight,I found that a few good catches, or heavy turning for a time without removing it, can make it a lot tighter. I have never noticed there being any run out associated with the washer, or without it. I have never noticed any extra vibration with it because the chuck or face plate is sticking out farther from the headstock. I have never had anything come off the lathe from stopping it, or putting it in reverse.
robo hippy
Re: Thanks for all the responses...
>Pretty much an even split between washers and no washers. I'm thinking that I have to get one the next time I go down the mountain and give one a try for a while.
Dennis Yoder
>JL just cut one out of a coffee lid and save yourself a trip. Dennis Y
Ed Wujciak
>I'll cast another vote for the coffee lid. Lasts a long time and the price is right....
Re: Was it exciting, Clem? :)
Allen Neighbors
Allen Neighbors
>Jerome, I've never used one, and have never had any stick that they wouldn't come off.
I screw on the chuck, with an easy hand, up against the shoulder.... then I put the wrench on it, and with the spindle locked, just bump the wrench with the heel of my hand to tighten it.
Then, when I'm ready to take it off, another bump with the heel of my hand will loosen it readily.
Clem Wixted, Jonesboro, AR
>No Allen,
It just loosened a little and I took my hand off and everything was OK.
Clem
