food grade finishes
Jim
>I am new to turning and want to turn bowls that can be used for food. What can I use to finish the projecrts? I've been told mineral oil isa good. What is the process to get a good shine and a finish that is not sticky?
food grade finishes
Jim
All finish is food safe after it cures
steve antonucci
>I use mineral oil because it's cheap, easy, and replenishable without taking the bowl out of service. You can drink it straight from the bottle, but I highly recommend you don't (unless you want to find out why!)
I also use beeswax if I want it to be a bit shiny,but it doesn't last. You can eat that too, but it's not too tasty.
Steven
Re: All finish is food safe after it cures *LINK*
Jeff from MA
>In addition to the above, carnuba wax is harder than bee's wax and works well. And pure tung oil, penetrates and once it polymerizes stays well. But make sure it is real pure tung oil and does not have any chemical or metal additives.
Below is a reference to an article on food safe finishes
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=26893
Re: food grade finishes
John Leonard
>I use General Salad Bowl Finish. They say on the can that it is food safe and I like the looks of the finish. John L.
Mike Rubes, Apex, NC
>Hi Jim,
I've had good luck with walnut oil and then topcoated with beeswax or carnuba wax. It provides a "matte" sort of finish, but I actually find it attractive. Plus, repairs are a snap, just rub in more walnut oil and some wax!
Good luck,
Mike
Had a good afternoon spin in Apex, NC!!
Re: Everything I can say about food safe finishes *LINK*
Russ Fairfield
>Follow the link
Is it Food Safe??
All modern finishes are safe
Mike Cunningham (Cape May NJ)
