OT Digital Camera problem
Jorge Castaneda~Downeast Maine
>Hello,
Today I was in a bowl turning class with a bunch of turners, when I tried to snap a pic of the bunch, this is what I saw
>Hello,
Re: OT Digital Camera problem
>Actually is not what I saw, the colors in the visor are more to green, but when written it changes some tp red & brown.
>I was to show another pic and accidentally posted.
Has anybody seen this kind of problem?
The temperature here was way below zero for a few days and the camera was in my car, so I thought once it thawed it would go away but it didn't. The camera read correctly previous pictures in the memory card.
What is happening?
TIA
Jorge
wilbur
>Is this happening with all of your pictures now? If so, I think something happened to the sensor, and I would bet that leaving it out in the cold might have had something to do with it. Maybe condensation hit your sensor when you brought the camera into a warmer environment. I don't know how water resistant the sensor is, but some condensation may be enough to really screw things up.
Unfortunately, if this is the case, I don't think there's much you can do except get a new camera. Luckily, it seems that 6 megapixels is all you need, and 6 MP cameras are pretty cheap these days. Besides, higher megapixel cameras may even make the picture worse.
>Wilbur,
Yes, now all the pictures are like that. If it is moisture, perhaps could be repaired. Interesting facts about pixel population...
Thank you
Jorge
>if it is moisture try putting it somewhere very dry for a few days. If you have a dehumidifier or dehydrator try putting it in there. If that doesn't work I'll bet it's toast because repairs are usually more expensive than the cameras anymore.
Re: The streaking you have .....
Jamie Donaldson
>...is a result of sensor reading errors, and it "may" be a result of weather/moisture damage. As John memtioned, if the camera has a removable len try drying out the camera, but if that doesn't help you are ready for a new camera shopping trip.
drying
JohnKJordan in East TN
>Gentle heat, such as a light bulb in a box, is recommended to dry out film and digital cameras with internal moisture, as well as other electronic things accidentally immersed in water. Remove any batteries and open all compartments, crack open the case if possible. (BTW, if accidentally immersed in salt water, the first thing to do is rinse and possibly soak the camera in a bucket of fresh water.) I once repaired a compact Olympus SLR film camera which had been dropped in a creek by a friend while hiking. I did have to disassemble it to clean and lubricate a sticking shutter (an incredibly complex and delicate operation!)
But if the camera here never works properly again, maybe you could give it to art teacher - the kids could have great fun with it. (you have to work hard to get a photo like that on purpose!)
Re: JohnK- I thought of that too!
Jamie Donaldson
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>The vertical streak doesn't look like what I would expect to be from moisture. It looks more like a really slow shutter speed, like maybe having it set for the smallest aperture. Have you checked out all of the settings, to make sure that you have not gotten on a button by mistake?
Are you normally pretty good with the camera, and know the tricks to use most of the settings offered?
Maybe posting the brand, and model would give someone a chance to see what settings would cause this.
eaglesc
>Try opening the shower curtain :>)
Glenn Hodges, Nashville, GA
>I whacked mine on the hand, vs using a larger hammer. It started working correctly again.
Re: drying
>John And John,
It never got actually wet, but it was in deep freeze a couple days, then this weekend found this creative outlook on things, something like an extreme astigmatism, maybe I will be modern day El Greco,
I will try the gentle heat in a box and will put some silica gel bags in there too.
If it does not get back to normal I follow your advice and give it to the art teacher : o)
Thanks for the advice guys!
Jorge
>It looks like it,
here I come D 80!
>Keith,
Yes I am very familiar with the camera, The first thing I did after finding the problem was to restore defaults, it did not change.
It is a Nikon 5700.
Thanks
Jorge
>Glen,
I tried your method, still no go, thanks.
Eagle
Like this you mean?
Jerry Whitaker
>Jorge, I can't help you out on this one and I know you have a problem but that is one nice piece of art better than a lot of the abstract paintings I have seen. I'm sure this does not make you feel any better. Hope you get it solved.
>Thanks Jerry,
The art thing is starting to be a consensus...
Re: Jamie got it, Jorge...
Allen Neighbors
>Moisture. Taking it in from cold to warm, it should be put into a camera case that is cold also, and allowed to come up to room temp inside the case. Is your Nikon a digital SLR?
I think maybe the moisture (condensation) collected on the inside of the camera, on whatever a digital camera uses to register the image, and has streaked down that surface. Try sitting it on the end and see if it changes the direction of the streaks... if so, that's what it is.
The drying technique explained above should do it... opening every compartment and cover you can, to let it dry out. I wouldn't apply too much heat.
Bob Macgregor
>What the heck, "when life gives you lemons...": put a title on it, frame it and sell it at the local gallery! That is an interesting effect; you might want to buy a new camera for shots with greater information content, but keep this one for weird, artsy shots!
>Bob,
My daughter said the same...:o)
I see dead people...
Ted Owen, Pittsburgh
in from the cold
>I meant to mention - when bringing things in from the cold, there is something simple you can do to protect from moisture condensation. Place the object in a plastic zip-lock bag and seal it up tightly while out in the cold. When you bring it inside, let it warm completely before opening the bag. This way, most of the moisture will condense on the outside of the bag instead on and inside the cold item. Same for things purchased and left in a cold car trunk for hours - leave them in the packaging until good and warm.
The plastic bag method works well for small things like cameras, cell phones, GPS units, electronic games, portable DVD players, and other things with battery doors and openings that are not sealed for moisture resistance. Watches, binoculars and small kids are usually pretty well sealed and don't need to be bagged.
Thanks John and all.
>Your tips are now "archived" in my mind and will put them to good use.
A friend did searches and came with something I did not expect, it is a well known issue with that camera (and some others) and Nikon replaces the sensor for free!
so I am sending it : )
Thanks anew
Jorge
