>My new lathe is on order. Now I want to consider a bandsaw. Can someone give me some insight as to what to purchase, brand size ect. Like anything esle, I don't want to buy something under size, and have to replace it. I like to turn bowls and hollow forms. Thanks in advance, you all have been so helpful. Steve
While it may not be the "perfect" saw, I recently picked up the Craftsman professional 14". Iron wheels, roller-bearing guides (whic are easily adjustable, 1hp 110/220v motor, two dust ports, storage underneath and 8.5" in cutting height. It came with a 1/4" blade (around 6tpi but I don't know) and even with it I have had no problems cutting 7" and 8" wet maple. I'm really happy with it.
>I use a 14" saw with a riser block (Delta) that will cut about 12". I've processed a lot of turning stock with it and it's done fine. If I were buying new today, however, I'd get a larger saw with a stronger frame that will better handle blades over 5/8".
>For a bowl turner, the most important three features are power, power, and power. Steel City has some excellent reasonably priced bandsaws you should look at before buying.
>I have a Delta 14" saw with a riser block. The saw and I have a love hat relationship. I added better guides, a Carter blade release, Dust collection, the riser, and I don't know what else. If I had known I would be adding all the upgrades, I might have bought a bigger saw to start with.
Like many here, I am a hobbyist and I switch from turning to flat work. I switch form bowl blanks to resawing wide planks to cutting little curves. It seems I am always changing the blade and networking the saw. I think I need two saws. One for resawing and "straight" cutting and one for circles and bowl blanks.
Carefully think about what you want the saw to do and buy one that fits the job. Bigger is better and more power is better. Most big brute over powered saws will accept a small thin blade and do fret work nicely, but a small under powered saw will not do a good job of cutting big honking bowl blanks or resawing.
>I upgraded from a 14" taiwanese to a used Delta 14" with Riser block. It only has 3/4 hp. I'm perfectly happy with it. It's cut everything I've asked of it up to the full 12" or resaw. I use an inexpensive 1/2" 3 tooth blade that I get from my local saw sharpening service.
I really can't imagine what I would do with more horsepower. It would probably let me cut faster but then I'd probably get in trouble. I have dreamed of getting a bigger stronger bandsaw but I'm not sure why. The only problems I've had is the size of the table is too small and the dust collection sucks.
>It depends on how big of bowls you are going to be turning. I have a 16 Laguna HD with a 5 hp motor, which was about $2,600 shipped. I use it to cut the sides of a blank parallel, then a smaller industrial Powermatic for cutting the blanks round. Sometimes I wish the PM cut a bit higher than the 6 inches it does, but a riser block cannot be added to it. A chainsawn blank works, but a bandsaw with the right hp and blade is far better, faster, and safer. You also get a blank that is more even so there is less time spent roughing out. I never use the electric chainsaw any more.
I thought the same way. I bought a large Grizzley Bandsaw 154" blade lots of power etc. And to this date I still prefer to use my chainsaw to cut my wood in prep for the lathe. I do use the band saw but just not as expected.
As far as bowls and hollow forms all I need is the chainsaw. I use a couple of Stihl 310"s. After I split the usable log I set it on a large log I have standing on end. I set the flat side up and wedge the bottom for stability. I use a large compass to mark the circle and trim to that. When I draw the circle I mark the center point on the wood to help in aligning on the lathe.
>Clem I haven't had time to download the photos and ask the question. I just worked on my bandsaw to seal it up and improve my dust collection. It works great since the lower wheel and also the upper wheel have virtually no dust inside the housing.
However there is still a huge amount of dust and debry that collects all over the table and consequently falls around the machine. I'm guessing that it either comes directly from the blade or somehow manages to run all the way through the machine and then comes out on top of the workpiece. By the time I'm done cutting several blanks I have a lot of mess to clean up.
>I have a Grizzly 14" with a riser block that I have been happy with, but it only has a 3/4 horse motor. If I were to upgrade today I would get another Griz only with a 2 hp motor.
I assume you got a biger lathe. If you are just going to be using the bandsaw for cutting turning blanks for your new big lathe, I would think again. I have a Jet 14" with 6" riser and I upgraded the motor to a 1 1/2 HP motor about two years ago. I would still prefer to rough cut blanks with the chainsaw. I find that handling a 23" blank on the small table of the bandsaw to be extremely dangerous. Plus, after I round off the blanks with the chainsaw, I don't have to cart the waste out of my shop like I would if I used the bandsaw. I cut my blanks about an inch less than the swing of my lathe and it has worked out great. Good luck with your new lathe.
