Longworth chuck
Longworth chuck
Longworth chuck
Eric in Los Gatos
>Has anyone built the Longworth chuck described in the April 07 issue of Popular Woodworking? Any thoughts, impressions or experiences would be welcome input as I'm thinking about making one. My only concern at this point is that the article calls for MDF as the material for one of the plates and I wonder how it would wear compared so something like plywood. I did a 4 year search but didn't see anything useful.
TIA for any advice.
Eric in Los Gatos
Re: Longworth chuck
Re: Longworth chuck
Nick Tuzzolino
>Check the articles section. Excellent tutorial by our own Garrett Lambert.
Re: Longworth chuck
Re: Longworth chuck
Jorge Castaneda~Downeast Maine
>Eric,
I had the same concern so used thick plexi-glass or acrylic, don't remember. It worked fine but was limiting both in the smaller and bigger sizes, I use vacuum now.
Re: Longworth chuck
Re: Longworth chuck
jared
>I built the one that was described in one of the turning magazines, I believe it was woodturning design, a couple of years ago. It has 6 locking pegs on it rather than the 4 that some use. It works real well and would recommend it to anyone. the directions were clear and a basic grasp of geometry is all that is required. Jared
Re: Longworth chuck
Re: Longworth chuck
Allen Neighbors
>Eric, I built two of them. I made the first one too small for my larger bowls, so I had to have another one. :(
I used 1/2" Baltic Birch Plywood for both disks, Cane Tips (with fillers of vinyl tubing inside to keep them from collapsing) for the buttons. I used a 4" faceplate as the center of the hub on my large (23.5") one, and a faceplate of Paulope (that fits in my 47mm Spigot jaws on my SN2 chuck)for the smaller (15.5") one. There's not enough flex in the plywood to be noticeable.
They both work perfectly. You can't lose with a Longworth. The only drawback is that the smallest size of the piece is determined by the size of the faceplate. But for anything that small I just use a jam chuck.
Re: Longworth chuck
ditto for me allan
robert davis
Re: Longworth chuck
Yup
Ralph
>I agree, the six-point design is superior to the conventional 4 point design.
Re: Longworth chuck
Re: Longworth chuck
Bill Clark
>I also built one out of 1/2" Baltic Birch. I made mine with 8 pegs and found some design problems cutting the slots. The slots overlapped the pin location for my router jig. I recommend using 6 pegs to avoid the problem.
Re: Longworth chuck
Re: Bill I put 8 pegs on mine...
Allen Neighbors
>but I cut mine with a saber saw. I cut slow and sure, and then used a small course rounded file to smooth the slots. Smooth and slick.
Re: Longworth chuck
Longworth Chuck *LINK*
Fred Holder
>Over the years, I gathered considerable material on the Longworth Chuck and put it at my web site. The first article was the one printed in Woodturning magazine several years ago. Then there is one other article and several pictures. I've never built one, but own two that were made using unbreakable plastic incstead of wood. Here is the link to the Longworth Chuck material: . If this link doesn't work, simply go to my domain site, select More Woodturning then scand down to Longworth chuck. They are a nice way to turn a bowl around if you don't have vacuum chucking.
Fred Holder's Domain Site
Re: Longworth chuck
Re: And much cheaper, Mr H...
Allen Neighbors
>thanks for posting the instructions on your Website. I used your directions to build mine. 'Cept I didn't use a router... I didn't have a decent bit for it, and didn't want to wait to order one in. :)
