balancing system *LINK*
>Thought you might find this interesting if you frequently turn out of balance pieces. Vicmarc is producing some very interesting gadgets.
http://www.vicmarc.com/default.asp?contentID=550
Imagine grabbing for it like a handwheel?
steve antonucci
>Only once...
steve
Re: balancing system
Fog Tanner
>Mine is supposed to be here in the next week or so. I "bought" it back in October, but there was a larger than expected demand so they were running behind. After that it has been on a month long boat ride from Aussieland and a week (or more) in customs. So, I can start watching for UPS starting today.
I did get a chance to look at one in person before buying it. It is a very interesting device. The steel spindle replaces the hand wheel and is threaded on the outboard side so you can still use the hand wheel. I have a habit of using the hand wheel as a brake so I am undecided as to whether to leave it off (and remove the impulse).
The two weights are fairly thick plate steel. They have holes machined off center so they may be positioned at any location. They are locked in place by set screws and are easy to adjust. There appears to be a slight learning curve to where to adjust their location as the piece becomes more balanced (as opposed to a SWAG). Like the Vic hand wheel and chucks, they are machined for a retaining ring to keep the assembly in place. This works if you have a Vicmarc lathe, which is what I am placing mine on.
If you do offcenter work, which is all I am doing now, this item is another "must have" tool. It is well built and cheaper than I could make it myself. I know they come threaded in three differnt sizes at least, 1 1/4 x 8 amd the two metric equivlents. The outboard external thread on the one I am getting is 1 1/4 x 8, which is also the internal thread size. The down side for a number of people that use Delta's, some Jets models, and possibly the Powermatic's - is you will have to mill or cut a slot in the motor for clearence (easily done by any good machine shop). Vicmarcs and Oneways should have no modifcations required.
Fog
I have a problem liking this approach.
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>While I am sure you can find a center of balance using these relative to the wood on the other end of the headstock, and everything below the bed, and down to the floor should feel less vibration.
However having one end of the arbor out of balance relative to the other, is just going to double the amount of force on the bolts which fasten the headstock to the bed. I would have some concern for this over the long term.
Since Vic has a fairly tall slender headstock, this makes the situation even worse from the leverage standpoint. I would feel better if there was a way to do the balancing on the same end as the faceplate.
Is this something that other brands have been doing, or is this new engineering for Vic?
I am not an engineer, nor do I play one on TV, but this challenges my natural aptitude for this sort of thing.
I have the same concern.
Brian Hahn in SW Wisconsin
>They have two masses that are out of balance in opposite directions. That is going to put a LOT of torque on the headstock and double the abuse that the bearings are taking.
It is much, much better to put the balancing weight next to the piece of wood.
Re: Keith and Brian...
Allen Neighbors
>Wouldn't putting the balance system on the same end of the spindle as the wood, cause more damage by placing all the stresses on the one bearing, rather than two? Just curious.
>It is best to put the balancing system next to the imbalance. It's purpose is to compensate for the imbalance in the piece you are turning and putting it on the same end of the spindle minimizes the stresses on the bearings. It is just like putting weights on your car wheels to balance the tires.
JohnKJordan in East TN
>I agree. The bearing stresses will be lower closer to the imbalance. Imaging a holding a dumbell with two opposing off-balanced ends. Spinning that would put heavy stresses on each end of the handle.
>I thought that putting the balancing feature on the opposite end made about as much sense as finding you needed to balance your right front tire, so you put the weights on the left front.
