OT- help shrinking a file
Steven Kubien
>Me again,
I shot a short video at the dojo last Friday and I want to email it. Problem is it is 248mb in size and it crashes my email program. I can't figure out how to shrink it or compress it of zip it or whatever. Can somone point me in the right direction?
Thanks,
Steve Kubien
Re: OT- help shrinking a file
Robert Henderson
>Video files are usually already in a compressed format.
Not much you can do except split it into multiple segments and email them selerately
Steven Antonucci
Probably not going to work
steve antonucci
>Most e-mail servers have inbound limits much lower than that. Even if you could get it out, someone probably can't receive it.
You might be able to load it to an FTP server and have someone download it. I don't know if Youtube has file size limits?
Steven
Mike Brazeau
>Steve - have you looked at Windows Movie Maker. I was just looking at it today on our system, but haven't used it. You can download from Microsoft if you don't already have it on your system. I think it will shrink resolution for you for emailing. You may have to chop it up somewhat. Just Google and you will easily find it.
JohnKJordan in East TN
>Steven,
There are definite video quality factors related to the size of the file. Before I retired last year, I struggled constantly to get the best quality for the smallest file. To decrease the file size of any video file, you must do one or more of these things:
Change the video codec (some are far better than others)
Increase the compression amount (smaller file=worse picture)
Reduce the image size (the number of pixels across and down)
Reduce the frame rate (e.g., 10fps vs 30fps)
Reduce the length of the video (edit out what you don't need)
We generally found a good MPEG variable bit rate encoder gave the best results. (Sorry, I don't have any recommendations for anything inexpensive) You can FTP far larger files than you can email, or put them on your own server and let the recepient download. If the files could not be reduced enough to tranfer electronically, we would send a DVD or video tape instead by Fedex or US mail or courier. If a large video needed to be on the net, we would have it put on a server and streamed.
If you want some idea of what is reasonable with your file, you might list the file type, encoder, image size, frame rate, and length of the video and someone may be better able to advise.
Juergen
>Don't worry about shrinking your files. Goto http://www.pando.com. What happens here is you upload the files to their server using their software, an email gets sent to the recipient, the recipient has to also install a small utility which connect to pando and dowloads your treasured unshrunk movie. There's a max file size and the FREE version is usually a little slower than the paid version. I've used this system for a while and it work well considering the price.
This site is also free with no size limit or software install. Good luck
http://www.sendthisfile.com/?rc=filetransfer-y#cooliris
>Looks like very nice service. Just hope the intended recipient of the 248meg file doesn't use a dialup modem!
Thanks everyone
Steven Kubien
>So it looks like I need to adjust things on my camera before I shoot next time and I am kinda toast this time. Fair enough. I can live with that. I'll throw it on a cd and give it to Sensei on Friday.
Again, thanks.
Steve Kubien
Re: Thanks everyone
Actually, everything you need to do can (and in most cases, should) be done on the computer after the video is taken. It is generally best to shoot at the highest possible quality, then edit and process "down" as needed.
