Redwood Lace Burl Hollow Form
Barry Turner
>I'm almost ready to finish my hollow form. I'm leaning towards a Watco Oil finish. Or maybe Tung Oil. Any opinions out there? Thanks.
Barry Turner
Re: Redwood Lace Burl Hollow Form
Carole Valentine
>I prefer Waterlox which is a tung oil based finish. As I recall, Redwood really soaks up finish so you might want to put on a coat of whatever you use, wipe it dry and then let it cure before applying additional coats. That will seal it a bit. Do you want gloss or satin or something in between?
Mike Stafford
>My only experience with redwood lace burls has been a couple of boxes and a few pens. Oil does tend to darken it quite a bit as the redwood soaks up so much. I finished one box with a wipe on poly and that also darkened the wood some but not as much as the oil.
Bill Neddow
>I cannot tell you whether Watco or Tung Oil will work best -- but stick with an oil-based finish rather than a water-based finish. Normally, a water-based finish will not darken a wood as much as an oil based one does. I was finishing a Redwood Lace Burl bowl yesterday (the first I have ever done) and was planning on using a water-base to keep the color light. Luckily, I tested it on a piece of scrap first. The wood soaked up so much of the water-base that it was twice as dark! There was no question of putting on a thin coat -- the wood just sucked the finish out of the paper towel. I had more success putting on a thin coat of oil-base. Last night I added a second coat, and it is really beautiful.
Lacquer is another choice. It often leaves the wood the most natural. But, if you decide to try it, test it first.
Bart Rhoads
>I have turned several pieces of Redwood Lace Burl and in my experience both oil and WB poly will darken the wood to the point you just about lose the burl. The best finish that I have found for this is lacquer. Just my opinion.
lacquer, deft, works best for me
robert davis
>deft sanding sealer while on lathe, couple coats deft satin still on lathe.
you might consider...
GaryG in MD
>...spraying on a few coats of clear shellac from a spray can. In my experience, you get some grain popping (not as much as with oil, of course) and not so much darkening. The first coat will soak in unevenly, but it will really help block the sponge effect. With the sprayer, you can emphasize the areas that soak up more. The shellac can be buffed out to a nice soft finish, or you could go over it with a matte acrylic spray -- which actually buffs out to a very nice shine. ...Gary
keith zimmerman, Normal IL
>Glad to see you got the hollowing technique figured out. Seems you were experiencing a bit of frustration.
My suggestion is Waterlox, but it will probably darken the wood, so a lacquer may be better.
Can't wait to see the finished piece.
keithz
Barry Turner
>Yeah.....I was frustrated. But, I was also tired. I finally just gave it up on Saturday and didn't go back to it until Tuesday. I started fresh.....and with sharp tools. It went so much better.
I'm looking for a finish that will bring out the richness and color of the redwood. I don't mind if it darkens....just as long as it's not so much that it obscures the beautiful grain patterns. I'm still leaning towards Watco. After a seal coat of Watco to pop the grain, maybe I will switch to a few spray coats of Minwax polyurethane. Thanks for the help.
As for a photo, posting photo's to this board is something I've never quite figured out. I'll try to email you a photo once it's finished.
posting photos
GaryG in MD
>Barry,
Posting photos is really very easy if you have a photo program that resizes and compresses jpeg images.
1) In your photo program, resize the photo so it easily fits on your computer screen when it is displayed at "1:1". Depending on your camera, this will probably mean using a reduction value of something like, say, 20% or 25%. Save it (perhaps with a new name). Look at the new file size. If it's less than 80kB, skip step 2 and go to 3. If your photo program doesn't have a compress function, you may have to resize to a smaller percentage to get the resultant file size below 80kB.
2) In your photo program, compress the resized image so the file size is under WC's 80kB limit. Save it again (perhaps with a new name).
3) On WC, click the "post message" link and type your message in the WC message text box.
4) Below the WC message text box, to the right of the WC "Optional Graphic Upload" window, click the "Browse" box and browse through your file structure to the folder that contains your resized, compressed image and double click the image name. It will appear in the WC window.
5) Go below and click the WC "Post Message" box, and you're done.
Do NOT click the "preview message" box or it will not work.
It's really easy -- give it a try. ...Gary
