Don't be like me! (Dark humor, important message.)
Craig Daymon
>I know, I know, many of you out there say to yourselves,"if I could only be a mediocre turner like Craig Daymon, maybe some day". Well, as much as I appreciate your sincere admiration, it is undeserved. I do STUPID things when I turn and I will soon be posting signs in the shop to remind me NOT to do so.
Today I was finishing the inside of an in-turned bowl (slightly smaller opening than it is in diameter) about 9" in diameter and 4" deep and I had a slight ridge near the bottom I wanted to remove. Aside from that one ridge, the inside was looking pretty good. That's when stupidity struck HARD! Use a curved cabinet scraper! (Please kids, DON'T TRY THIS AT HOME...OR ANYWHERE ELSE!!!) I've used them on the outside of bowls with great success, so how bad could it be? (Again, STUPIDITY!)
Well, my hand was inside the bowl with the scraper and it caught. It spun around inside the bowl (again, my hand was in there too) slicing into my wrist down to the bone. Cut a tendon and at least one nerve. The top of my pinky finger is numb and I go to see the hand surgeon tomorrow...which I hope won't mean any additional work beyond the current stitches.
So, take my picture off the shop wall and remember to always think through the possible consequences (a.k.a. all necessary projectile and escape routes) if you are trying something new. I was wearing a face shield, which was also a GOOD THING!
-Craig (intelligent does not equal smart) Daymon
BTW, it looks like the bowl will survive. (I know some of you were worried.)
Re: Don't be like me! (Dark humor, important message.)
Allen Neighbors
>Craig, as soon as I read this, I ran out back to the shop and removed your picture. Sorry... just couldn't resist. :)
I'm sure glad you posted this... It wasn't long ago that I had it in mind to get a set of scrapers so I could use the curved one inside. I won't do that now.
I'm sorry for all your pain, and I hope your surgery goes well and they get you put back together right. Her Majesty and I will lift you up in our prayer time tonight. I hope you heal fast with no bad after effects, other than the memory of course.
Jim
>Ouch. That's a real drag. I hate it when stupidity strikes like that. I've got a slice in the side of my thumb this year when I didn't think about what direction I was pushing a freshly sharpened chisel. Many stitches later... I went back and did it the right way. The project has long since gone out the door, but the thumb has never completely returned to normal
Here's hoping you heal quickly and completely.
bummer dude.
>Never thought of using a cabinet scraper inside. At least not with the lathe moving. Now I know I don't want to try it.
Chip in Plano
>I could say the same about me. I stuck my thumb and ring finger in a band saw in June. I was changing the blade and balancing the blade. All was done and good and I just grazed the bottom wheel as I was motioning to hit the Stop button on the back of the saw. I was lucky that it didn't catch my wedding band else I would have lost my finger and probably a few others. They were very polite in the ER. Cut my wedding ring off with a really cool tool. 15 stitches later and I have lost a little sensation in my left thumb and some mobility. Took me out of turning for 2 months. And I still remain a little gun-shy of my band saw. I don't turn blanks round anymore. I nibble the edges. It's actually faster and less stressful. I've not had to change the blade since and there's still blood on the floor and walls.
The only thing I did wrong was not making sure the lower door on my 14"Jet was closed but it doesn't stay closed easily. And to test for co-planer wheels you gotta have both doors open. I just didn't shut it well enough when I turned it on to see if the blade would seat and track correctly on the wheels.
Ouch, that hurts! Get better soon.
adrien
Thank Goodness:
Ruth
>the bowl was saved!! Imagine if it was the bowl all smashed up and broken - sheesh, ya gotta be more careful Craig.
I sliced the side of my wrist 3 yrs ago. Just wasn't paying attention as my hand guided the chisel inside a very nice bowl I was working on. Fortunately that bowl too was saved and no blood on it.
Take it easy Craig, I hope there is no permanent damage.
JohnKJordan in East TN
>Craig,
Yikes, I'm so sorry that happened. It was painful to read and a good lesson - thank you for posting. Sounds like catching a hand in a food processor.
I use cabinet scrapers all the time on the outside. I do occasionally use one on the inside, mostly with the lathe off, but sometimes turning.
The scraper I use is shown below - I cut the end off a larger curved scraper with a Dremel tool and rounded the corners. I did this primarily since it was sometimes hard to get the full scraper to clear the work. I used it today in fact, to remove a small hump on the inside of a box, but I did that with the lathe off. I also use it for carvings.
Do you think this is safe to use inside of a turning holding with the fingers?
After your message, I'm thinking of mounting it on a handle. I have the Sorby multitool teardrop-shaped scrapers but I like this one better.
Don't do it.....
Wally Dickerman in Arizona
>Actually, I can't think of any good reason why you would want to stick your hand inside a spinning bowl with the hand held scraper. They make very good scrapers that have a wooden handle and a tool rest that will allow you to safely control the tool, which will do the job very well.
Wally.
Mike Stafford
Heal well and quickly!
Mike Stafford
>Craig, I have to applaud your attitude. I am afraid I would be too upset to approach this incident as an opportunity to teach.
I hope the repairs are done easily and you return to normal as soon as possible. So sorry to hear about the accident.
Re: Double ouch..
>I hope you can be "repaired". Thanks for the warning.
Not a good way to start the year,
Andi Wolfe
>for sure. I do hope you heal well and quickly. Thanks for sharing your experience with us. Ouch!
>Hope you heal well and quickly. I have done exactly what you described. Not anymore. I remember thinking, "this thing has a lot of sharp edges." Now I will listen to that little thought. I even considered taping the edges I was not using. We really should listen to those little waring thoughts. Thanks for sharing. Hope this was the low point for your new year.
I was puzzled by that as well.
Brian Hahn in SW Wisconsin
Re: Don't do it.....
>Oh, one thing I didn't mention - when I use any hand held scraper the lathe is turning at an extremely slow speed, the slowest my vs lathe will turn. I suspect that like driving cars, speed is a safety factor.
New color wash?
Mike Nelson
Craig Daymon
>John,
The speed was definitely too high. Also, NEVER EVER try this with an in-turned lip on the bowl. (Take it from someone who did, unsuccessfully.) I like your idea of mounting it on a Sorby multi-scraper or some such arm. Definitely better and safer, but keep it relatively small so it is less likely to snap and definitely wear a face shield/body armor/etc.
I know those beautiful angle hair shavings are a temptation, but the downside is pretty severe. As my brother described it after I told him, "It's sort of like sticking your hand in the garbage disposal." That's a pretty accurate description. After the surgery, it will be about 8 weeks before I can consider getting back on the lathe.
-Craig
Update.
Craig Daymon
>Turns out I cut one tendon and at least one nerve. I'll go in for surgery tomorrow to get those reattached, though there will still be some numbness to the right side of my hand for a while and possibly permanently. Following surgery, it will be about 8 weeks before I can get back to turning.
-Craig
Carol in Illinois
>Holy $%@*, Craig!! Oh my lord, I _felt_ that as I read it! I hope and pray that your hand and wrist will be okay. That's gonna be a permanent reminder to think three times before you do something. I'll be pulling for your swift recovery.
Carol from Illinois
Carol in Illinois
>Chip, I found the solution to the blood on the floor and walls is a couple of dogs on the spot as the injury occurs. DAMHIK
Dogs
Tim GC
>Yep, I agree, been there done that!!
George Van
>Thanks for the post, heal quickly!
Justin Fields
>Craig,
Thanks for sharing this. I applaud the honesty and the consideration for your fellow turners.
I skydive as a hobby, and post-injury analysis is taken for granted in the sport. There are too many potential mistakes to be made, and you won't surive going through them all yourself with trial and error. A key way to reduce risk is to utilize the opportunity to learn from the mistakes of others.
I'm sorry you got hurt, but glad you had the courage to allow us to have this post-incident learning opportunity.
Heal well and fast!
Justin
PS The slightly morbid side of me thinks you should leave the stains. I have bloodstains on my skydiving jumpsuit that I won't bleach out, as a reminder. ;-)
robo hippy
>I agree with Wally. A standard or negative rake scraper on a handle is better than a cabinet scraper and keeps your hands out of the way. I did try the hand held scrapers a few times (at very low speeds because they work better that way, and because my bowls are warped), and found that I could get the same or a better cut with my regular scrapers, especially when held at a shear angle. Pushing or pulling doesn't make much difference. The whisper cut (little fluffies floating in the air) is the way to go to get those marks out. This is not a stock removal cut.
robo hippy
Re: Don't be like me! (Dark humor, important messa *LINK*
Craig Daymon
>I'm impressed Justin, I thought skydiving was an all blood stain or none sport. Good to hear your still at it.
I've cleaned the blood off the smock (NOTE: Blood washes out of AAW turning smocks very well.) and I'll clean the floor because it might impact resale value.
I've ordered up a shirt, which is suppose to come with a matching poster, from the Darwin Awards site that I'm putting up in the shop as a reminder not to be so stupid again. Check it out, I'll put the link below.
-Craig
Tree of Life T-shirt and poster. Darwin Awards
