200+ woodworking book reviews
reversing motor on lathe
sedcokid
>I am new to turning and enjoy my new found hobby. I recently purchase a new Jet 14" lathe and like it alot, the motor is 120 volt AC. However, I would like to be able to reverse the spindle direction when sanding. How do I go about doing this? Has anyone done this before?
Re: reversing motor on lathe
>Simply flip the spindle end for end. That reverses the direction. You can't really reverse an AC motor that doesn't have it built in.
Re: reversing motor on lathe *LINK*
Eddie Pacheco; San Jose, Ca.
>Try the link below. I think the motor on that lathe is a capacitor start motor. With additional wiring and a DPDT switch you can revers these.
http://www.lmphotonics.com/single_phase_m.htm
John Lucas You Rule!
tm
>"Simply flip the spindle end for end. That reverses the direction. You can't really reverse an AC motor that doesn't have it built in. "
My Nova DVR XP allows me to reverse with a simple switch
but I'm doing some longer spindlework on my older Craftsman
and wanted to get them baby butt smooth.
Why didn't I think of that?
No, nevermind don't tell me why.
Thanks.
John
Re: John Lucas You Rule!
>TM That was a tip I picked up on the web. I had the same head slapper comment you did.
>I got my first lathe and motor when I was a kid, so that was literally forty years ago. It was a Craftsman with a tubular bed. The motor was separate and I made a motor mount with a door hinge on it and the weight of the motor tensioned the belt. A friend had a similar lathe and he suggested a method for a home made reversing switch.
It was a capacitor start motor that was reversible. There were wires inside the control box and for it to run forward you hooked A to A and B to B. To reverse it, you hook A to B and B to A or simply interchanged the position of the wires. (the switch mentioned above might be perfect for that, but I did not know such things existed back in the day. I think it has to be DPDT, though) What we did was wire a receptacle to the motor so that one slot on the receptacle was A and the other was B. Then we wired a short heavy duty cord with a plug so that one prong was A and the other B. To run one way, you just plugged the cord in. To reverse, you twisted the cord and reversed the position of the prongs. Obviously, this was a two prong plug and it was not a polarity plug with one wider than the other, it had to be reversible.
I, and later my son, ran the lathe like that for about thirty five years. I sold the lathe (for more than I paid for it) and was taking it apart for the guy who bought it. (He did not want the cabinet). I was removing the home made reversing switch and he stopped me, made me explain it and took it with him to continue using it.
We don't need no fancy stinking PDQ switches...
Bill Crommett
>If some one can reverse the motor on a one inch Delta band sander we could have a tool sharpener that John lusts for. Me too !
Allen Neighbors
>I think he meant the lathe spindle, John, not the spindle he's turning. :)
Re: Eddie Questions:
Allen Neighbors
>Does DPDT mean Dipole, Double Throw?
Where do you connect the extra wiring you mentioned in the above post.
Here's my problem:
I have a 1/2hp General Electric enclosed motor that is reversible by switching positions of the T5 and T8 wires.
I need some sort of switch that will allow me to do that without having to go into the electrical box on the side of the motor. Is that possible?
John Roth
>There are commercial/industrial motor reversing switches. You have to have a universal induction motor, which apparently you do have. I installed a reversing heavy duty switch made by Dayton on my motor. Check out W W Grainger; that's where I got mine. Works great with minimal wiring, although you will have to get into the connection box on the motor; no way around that.
DPDT means Double pole, Double Throw
Clem Wixted, Jonesboro, AR
Sent you an e-mail, Allen.
Barry Elder
>When I first started turning, on one of the turning sites there was a schematic showing how to reverse the motor on the 1014VS using a DPDT switch. You could probably search the different sites and find it without any problem. It was 3 or 4 years ago IIRC.
Re: Danke Schoen, Eddie. :)
Allen Neighbors
Bill Turpin in WNC mountains
>This is the general concept, insert your own numbers
