Cutting PVC on the bandsaw...........
Richard T Jones
>I saw a pic recently of a piece of PVC being cut on the bandsaw. Clamped some kind of way, splitting it endways, to use for chucking, etc.
Can't for the life of me find said photo.
Can someone help me out?
Many thanks.
Rich in VA
Re: Cutting PVC on the bandsaw...........
Dick Hines
Dick Hines
>Rich. if you have a chop saw that works better and I think safer than cutting with a band saw. If you must you can clamp it to the miter guide and to be safe put a wedge behind the PVC. And KEEP YOU FINGERS AWAY FROM THE BLADE.
Splitting PVC is safer than cross cutting, if you split the PVC right down the middle.
I don't like cutting anything round on a bandsaw. I do it some time but only if I can find no other way to get the job done.
JohnKJordan in East TN
>>...splitting it endways
Do you mean cutting down the length, like ripping a board?
If cutting short slots in the end and not splitting a long length of pipe, I use a v-block fastened to the table and push the round work into the blade. I've slotted wooden dowels this way but not PVC pipe. (I also use the bandsaw to make my v-blocks by standing the block on end.)
If you need to cut an entire length of pipe in half, it would be harder to keep it from twisting as the cut progresses. One way I'd try is to use the same type of v-block, make a saw kerf so the blade is half way into the block, fasten the block to the table, then fasten a thin vertical "splitter" in the kerf (made perhaps from aluminium) which will ride in the slot and help prevent twisting. I saw this in a magazine once. I can imagine a more elaborate fixture that would help keep long pipes from twisting. Or just draw a straight line down the pipe and follow the line!
>I glued a square block to both ends and fed it through my table saw. You could do the same thing with the bandsaw if you made long table extension. I would feed a board into the saw about 6 inches. Then turn it around and push the slot over the blade from the backside. Then clamp this in place. Hot glue a block to one end of the PVC and feed it through.
Richard T Jones
>OK, this is for a rip. IIRC, the jig was a sled, with a piece fastened to the sled, front to back, not like a cut-off jig. Then the pipe, a short section, like 12", was clamped to the front to back piece, clamp on each end.
Appreciate all the help, good ideas here, for sure.
Thanks,
Rich
>Rich,
I tried cutting slots in the ends of four inch thin wall PVC. I was installing my dust collector and wanted to put a hose clamp on the pipe and snug it down onto a blast gate. So I cut a bunch of slots about an inch deep making fingers on the end that the clamp could squeeze.
So my plan was to approach the bandsaw as if I were going to rip the piece of pipe, cut in about and inch, back out, rotate the pipe a little and do it again and again. I had a 3 TPI hook toothed blade on the saw and a 5" long four inch diameter piece of pipe in my hand. It took that piece of pipe away from me and threw it past my ear so fast I neither saw it or heard it. I was convinced I had been warned and was lucky to still have all my parts. After that, I used my jig saw.
(If I had known, I would have used a heat gun to warm the pipe and the pipe clamp could have just squeezed it down. Ain't ignorance wonderful?)
So, use a sled or some kind of blocks. Maybe a finer toothed blade. Or a table saw. Be careful. (Its good that you asked, because sometimes we don't even know what "careful" is.)
Darrell Feltmate
>Rick
I have done this before, sorry not to have taken pictures. One of the easiest ways is to use a v block, which has already been covered. Perhaps safer, is to make an L shaped sled the length of the pipe. The pipe is secured to the sled with a c clamp at either end or by screwing through the sled into the pipe wall. The idea is to keep the pipe from rolling. The foot of the sled is not under the pipe unless you consider the sled expendable BUT the foot of the sled and the bottom of the pipe should be in the same plane. I just set the two on the table saw and have them automatically lined up. From the end it sort of looks like OL . Clear as mud?
Richard T Jones
>Darrell,
Yes, exactly what I remember from the pic. The pipe actually hung overboard of the sled just a bit, but a sacrificial sled would be OK by me.
Thanks, looks like I'm in the game..............
Rich
Richard T Jones
>Barry,
Yep, I've ruined enough bandsaw blades by not having something clamped.........
I'll try and post some pics when I rig up something.
Thanks for the help.
Rich
