hollow turning demo technique
>Here is the method that i like to use while teaching hollow turning. I drill holes in the sides and spin the lathe at fairly high speed. Do this with sound wood of course. The holes let people see exactly what the tool is doing. It helps if you have video of course. turn the speed up or down until the camera has the best image.
It doesn't have to be 4 big holes. It can be a bunch or smaller holes which makes the turning easier. It also teaches you tool control because the tool cuts extremely rapidly in the void areas.
In this case I'm using the Hunter #1 with my homemade Jamieson boring bar held in an arm brace.
Re: hollow turning demo technique
Demo piece
>Here is the more or less finished piece. It has a work hole through the pith and several other bad work holes so I'll save this just for demo's
Steven Antonucci
It's also why I like burls with voids
steve antonucci
>Not only does it help clear out the shavings, but while turning, I can see the cutter in the shadow and measure wall thickness much better. The bigger the void, the easier it is to see. It doesn't need to be 4 holes- you could see the cutter with a single hole that size if you concentrate.
I could have used one yesterday when I cut through a 1/16" olive crotch hollowform that I was 90% done with. I didn't believe my calipers, so I kept cutting. I guess they were right.
HNY.
Steven
keith zimmerman, Normal IL
>Great idea John. I have a demo coming up in March about doing mini hollow forms. I'll have to try this technique to show the cutting action. Maybe it will work for me.
keithz
Stuart Johnson
>There are a couple videos on youtube that I stumbled on one day that shows hollowing under a flat top form. They are in German or some other language but you don't need a translation to see what is going on. The turner cut off two wings and it give a very good view of just how the wood is being removed. I'll post a link if I can ever find them again.
Nifty idea! Thanks, John.
Eddie Pacheco; San Jose, Ca.
Hey Keith
Terry Quiram, Roanoke Illinois
>I made a bowl today with the bottom cut out. Will that work??????
Re: Hey Keith
keith zimmerman, Normal, IL
>Sure, it will work, just not for my demo. When I can think of where it would work, I'll let you know.
Hope you had some good holidays Terry.
keith
